MotoNudo Build
Re: MotoNudo Build
Made some progress on the drive shat and swing arm. OF thinks the needle bearing remnants are from an old shaft. It has cleaned up well.
Is moly grease the way to go for the needle bearings?
1975 GW - MotoNudohttp://www.ngwclub.com/forum/viewtopic.php?f=16&t=55367
1975 GW - TBD
1975 GW - TBD
Re: MotoNudo Build
Got the brake lever off after much pounding. It was significantly rusted.
1975 GW - TBD
1975 GW - TBD
Re: MotoNudo Build
Yep, they can be stuck on good! Now time to do a little modification to get a grease zerk in there!
Re: MotoNudo Build
Tap the brake sleeve I assume?
1975 GW - TBD
1975 GW - TBD
Re: MotoNudo Build
Yep, tap the brake pedal sleeve, and be cautious as to where you put the zerk. I seem to recall that there is something about it in shoptalk.
Re: MotoNudo Build
So, crappy day. Had the timing down and was syncing the carbs on my bench setup. Next thing I know, white smoke, cycling RPM's, and dark grey coolant water. Blown gasket? I took off he heads, again, and one gasket was stuck to both sides and a piston seemed to have a oily residue. The other gasket came off clean with only a orange sticky residue around the gasket area. I am going to order some more gaskets (more $), clean the surfaces, again, and put her back together.
I used OEM gaskets, put some anti-seize on the head bolts to ensure a good torque setting, and torqued to specs. Anything else I should do?
Really bummed out on this one. I was hoping to get it on the frame soon..
1975 GW - TBD
1975 GW - TBD
Re: MotoNudo Build
Taking a break from the engine. I am looking at buying an m-unit from motogadget for lighting and starter control. I am going to sell off the lighting control unit, 7V regulator, resistor assembly, etc. but I am wondering about the purpose of the diodes as they relate to the starter switch, starter disconnect, etc. Any thoughts? can I get rid of the diodes?
1975 GW - TBD
1975 GW - TBD
Re: MotoNudo Build
Hi Lads, I just saw this. Sorry for the delay. To lower the rear, I use Progressive 420 shocks. You can order them in several lengths. The spring should be around a 110-120. On the front end, you can go with either a smaller diameter rim, or slip your forks up an inch in the tree. Would not hurty to pu progressive springs in to stiffen up the front.Sunnbobb, I had a couple,of questions for you. I am looking to lower the stance of the bike slightly. Any feel for the easiest way to do that? Lower the tree on the forks? Shave the rear shock?
I am sticking with the stock "tank" instead of the custom idea I had, maybe a later project. I am looking at clip-on bars to lower the riders stance as well. Do you think progressive shocks are in order? I am 185, probably will have a passenger every so often. I have heard various opinions, figured you may have looked into this.
Re: MotoNudo Build
Got the engine back on the bench after painting and now having barb problems. Significant flooding, coming out the exhaust connections, on the 2-4 side. After I disconnect the gas, the bike will run for another few minutes from all the gas in the system.
Anything else this could be other than the float? I want to make sure I check all potential problems when I get in there.
1975 GW - TBD
1975 GW - TBD
Re: MotoNudo Build
Could be three areas, float valves, oring between carb and plenum, and the plenum gasket between the plenum halves. To check, bike or carbs level, dry the carbs off, remove the slides and caps, dry the venturi throats off, and turn the gas on. Watch for leaks. To narrow down the leak faster, cut and fit a piece of paper in the plenum base to see where it occurs first. If it's the plenum gasket, it will get wet in the center along the seam. If it comes from the sides, you now know which carb/carbs leak. Dry they off again and repeat this time watching in the opening for the slides. If it is coming from the brass jets, it's a float valve. If it comes down the venturi from the plenum side, it's the fat o-ring that seals the fuel port between the plenum and carbs. All easy fixes, but carbs have to come off. Do yourself a favor and rig a test source of a liter of fuel from six feet above the rack and test it before reinstalling on the bike.
If your float gaskets are aftermarket, they are likely junk. Another issue is cheap bowl gaskets which fit nicely dry, but swell and interfere with the floats when gas hits them. You can see this if you're paying attention when you first remove the bowl. Good materials like Randakks don't swell.
Re: MotoNudo Build
Thanks, used Randakk's kit. The floats were on the bike so not sure if they are original but I think so. One of the float towers was broke and might have interfered with the low level stop. I did not replace the float valves.
1975 GW - TBD
1975 GW - TBD
Re: MotoNudo Build
I plan on taking the carbs off the silver bike and replacing #2-4 assembly. The #4 float tower was broken and I think that is what Is causing the flooding problem. The missing tower prevents the float stop from working. I have all the jets, gaskets,orings from the carb I just rebuilt and I will transfer them to the silver bike's carb assembly and then reattach to the #1-3 assembly I had already rebuilt.
This is what I found when I started taking apart #2-4 on the silver bike. Proof that it has been sitting for 30 years. Worst I have ever seen.
1975 GW - TBD
1975 GW - TBD
Re: MotoNudo Build
That is pretty bad, but I have saved ones that looked worse
Re: MotoNudo Build
Just make sure they are the same carb numbers. I just did a set of carbs from a bike that had a plate on it that expired in 1984. They were cleaner than the one's I did last week that had sat for 8 years. I know why.
Re: MotoNudo Build
I have a lot of catching up to do on this thread. Many of you have seen me popping up on other threads with electrical, brake, and various other topics.
Took a break from the carbs. I am going to check the bench sync but I have exhausted many of the great suggestions here and the list from Randakk's blog. Just really tired of screwing with them and need a distraction. i am going to concentrate on getting the bike put back together and then do another carb check right before I out the radiator and heat shroud in.
I got the wheels back from the shop. They laced 16" HD wheels on my hubs. I painted them black. Preped them real good and decided to do the rattle can route. I was concerned about powder coat holding up with the spokes and figured I could touch them up myself as required. Also painted the engine, same approach, satin black to keep the shiny down but still allow for easy cleaning.
Rebuilt the swingarm, greased all the appropriate joints and added a grease fitting to the rear of the swingarm in conjunction with the new seal from Wingovations.
Got new lines for the front/rear brakes and new hydro clutch. Decided to go with the double banjo on the fronts since I had a brake switch on the 94 masters I bought.
Also did the electrolysis method for the tank de-rusting, it went great. I used the Arm & Hammer detergent from wally world and made sure to clean the base metal often. Please note that anything in the solution that is rust will disappear (that's the point) and includes rusty output screens and the tiny screw that connects the fuel sending float to the shaft.
Here are a few pics of the current state. Sorry I don't have the pics of the individual work. My iPad went missing a while back and it had all the pics on it.
1975 GW - TBD
1975 GW - TBD
- 69 Replies
- 9026 Views
Last post by gearhead4207
- 55 Replies
- 7717 Views
Last post by codyjames707
