*Accident Repairs / Fork Swap* 75 Wing Cafe RestoMod
Hanslehoff
Re: *Accident Repairs / Fork Swap* 75 Wing Cafe RestoMod
#631
Post by Hanslehoff »
Couldn’t come up with a cheap right control I could dissemble and rob the missing kill switch parts from. Came up with a fix that should hold up - Drilled a very small hole through the base of the kill switch shaft in the groove where the circlip would go. I found a little ball chain in a junk drawer that was just the right size to replace the missing ball bearing and then I used a carb linkage cotter pin on the bottom to hold it all together.
Sugs
#632
Post by Sugs »
Nice hack! If that necklace ball turns out to wear too easily(aren't they hollow? maybe not?) you can go to a hobby shop or website for r/c cars and order some "diff balls". Come if various sizes and are hardended.
_______________________
'79 Honda GL1000 Goldwing
Hanslehoff
#633
Glad you messaged, that coulda been bad :shock: My axle didn’t come with them either, I couldn’t find decent used ones so I ordered new spacers on partzilla. Should be way more CBR1000 parts out there tho, the RC51 axle was rare.
For the steering stops I cut and filed the stock ones off then drilled holes for bolts like you said. My thread has a description and pics on pg 23 and 30. The first ones I did weren’t quite right so I redid them after everything was powder coated
Hanslehoff
#634
I know I’m in the minority, having raised my bike rather than lowered it, but I finally found a solution to the too short stock kick stand.
Kickstand from a 1980 CX500 Custom
On the left is the stock stand and on the right is the CX. It’s about 1-1/2” longer and the spring and rubber are identical. It needed a little bit of file work on the mount to widening it just a hair and I cut the little hoop off the side, but other than that it bolts right on. Just going to finish cleaning it up and give it some fresh paint.
Patriccio
#635
Post by Patriccio »
Such a nice looking scooter.
If there is one thing I have learned throughout this process it is this: Check your respirator for spiders before you put it on.
5speed
#636
Post by 5speed »
Patriccio wrote:Such a nice looking scooter.
:shock: he's alive!!!! anim-cheers1
codyjames707
#637
Post by codyjames707 »
Nice dude! Definitely the right call shaving those things off too! AND a smooth way to add an inch or two!
1977 Gl1000 DARKGREEN-WING
BOTM April, 2018
viewtopic.php?f=16&t=59710
Henry McCann
Brass Member
Brass Member
#638
Post by Henry McCann »
Really enjoyed this thread!
So happy to see a front fender. I have never gotten used to a bike without a front fender, though many love the look.
Congrats on lots of attention to detail and fine craftmanship!!!
