Customising my first Goldwing
Sugs
Re: Customising my first Goldwing
Post #46 by Sugs » Tue Dec 01, 2015 1:04 am
You can check out my thread and take a look at what I've done to my seat for some ideas, scroll to the bottom. viewtopic.php?f=16&t=57962 I started using a belt sander with coarse grit to get it where it is now, it does get thin real quick on the sides so go easy. Still have to get it covered but haven't had much time lately to work on the bike, will get to it eventually.
_______________________
'90 Honda CB-1
'79 Honda GL1000 Goldwing
UK_Andy
Post #47 by UK_Andy » Mon Dec 07, 2015 11:01 am
Fitted my new cam belts this weekend, slightly scary but it all turned out good and the engine runs smoothly.
Seat is on hold while I decide on wether to trim the plastic sides down to get a narrower seat.
UK_Andy
Post #48 by UK_Andy » Sat Jan 09, 2016 11:32 am
Got a Triumph seat off ebay for the princely sum of £1.20 ($1.74) +£8 ($11) postage so even if I get it completely wrong it will not matter much.
Question is...where do I cut the front to make it fit?
wingrider
Post #49 by wingrider » Sat Jan 09, 2016 12:02 pm
Good price on the seat! If I remember correctly, Octane showed the cuts he made when he was building the Bulldog. Have to look into that myself, as I have one to hack up too!
wingrider
Post #50 by wingrider » Sat Jan 09, 2016 12:12 pm
About the best picture I could find is in the first page of one of Octane's threads...bit down the page located right here.
UK_Andy
Post #51 by UK_Andy » Fri Mar 18, 2016 4:10 pm
Iv been looking at some new shorter shocks for the bike and found some in my local shop. Unfortunately it doesn't say what bike they are for but heres the specs.
Are these strong enough for a gl1100 with pillion
Dimension:
Total Length:315mm (12 3/8")
Length of Eye to Clevis Eye Core:280mm (11")
Clevis Hole Diameter: 8mm
Clevis Inner Width: 20mm
Clevis Maximum Tensile Strength: 2,000 Kgf
Spring Thickness: 7mm
Spring Width: 60mm
Spring Stiffness: 110 kg
Maximum load: 150kg (≈330 lbs
Air Reservoir: Adjustable
Factory Air Pressure: 0.4 Mpa
Maximum Air Pressure: 0.5 Mpa
UK_Andy
Post #52 by UK_Andy » Sat Mar 19, 2016 11:57 am
My seat is coming along nicely, took it to a local car seat company. Oxted Trimming Co. in Oxted, Surrey. UK. They make all the seats for the Caterham range of cars in the UK so they know what they are doing.
So, this is the final shape and it will get covered this week in a nice vintage style distressed brown vinyl with diamond stitching.
You can also see in the fist two pics that I bobbed the rear mudguard
Hope ya like it :-D
Post #53 by CYBORG » Sat Mar 19, 2016 1:34 pm
Brown seat on a black bike???
UK_Andy
Post #54 by UK_Andy » Sat Mar 19, 2016 2:52 pm
CYBORG wrote:Brown seat on a black bike???
To be painted later
Post #55 by CYBORG » Sat Mar 19, 2016 3:15 pm
O.K.
Post #56 by ericheath » Sat Mar 19, 2016 5:50 pm
Looks awesome.
230Rocket
Post #57 by 230Rocket » Wed Mar 23, 2016 11:39 am
Andy,
Looks like your seat came out really good, I screwed up a little by cutting too much off the baseplate at the front where it needs to meet the tank and subsequently I then took too much foam out. Luckily these seats aren't rare so I have another to play with. Do you have any additional pictures of the foam or baseplate cutting you did? I'd like to follow similar lines of yours.
Great job on the whole bike, it's good to see the vision coming together.
cheers
Dean
1982 GL1100 Fat Turtle
UK_Andy
Post #58 by UK_Andy » Wed Mar 23, 2016 12:41 pm
I didn't take any pics after but I made these cuts, about 5mm off the bottom edge and the other two cuts to shape it
And rounded off the back edge a bit more.
When I get the seat back Ill take a few pics for you.
230Rocket
Post #59 by 230Rocket » Thu Mar 24, 2016 9:40 am
superb! exactly what I shoulda done! I'll keep an eye on things here...
cheers
Dean
Steevensi
Post #60 by Steevensi » Thu Mar 24, 2016 10:54 am
Do you have pictures of your new seat??
The Black Bike
http://www.ngwclub.com/forum/viewtopic.php?f=30&t=59312
1982 GL 1100
1980 GL 1100 to be fix
1983 Honda Nighthawk 650 sold
1980 Suzuki A100
1974 Suzuki TS 250 sold
1992 Yamaha RT 180 sold
1976 Honda CB125 sold
2002 Suzuki Katana 750 sold
1982 Suzuki GS750 in boxes
Who is online
