Thanks buddyBuli wrote:Hello. Nice to see u . And bike is great
My naked MAINE-WING build.
- BikeMaine
Re: My naked MAINE-WING build.
Kevin
1982 GL1100A
1982 GL1100A
- Norbert R
Brother that's looking awesome! If I were you I'd leave it just like that, no top box.
You still gonna wrap your pipes? Will look good IMO
Enjoy your Ohio ride!!
- BikeMaine
Thanks Bro!Norbert R wrote:Brother that's looking awesome! If I were you I'd leave it just like that, no top box.
I put on the top box, BUT ONLY FOR THE OHIO TRIP.
yes, I'm wrapping the pipes, the wrap is doodling in water now.
Kevin
1982 GL1100A
1982 GL1100A
- toolbox
Looks good! Looking forward to seeing how the wrap turns out .
- BikeMaine
Me too! Hahahatoolbox wrote:Looks good! Looking forward to seeing how the wrap turns out .
Kevin
1982 GL1100A
1982 GL1100A
- BikeMaine
Just got the wrap on the left side header and tail pipe.toolbox wrote:Looks good! Looking forward to seeing how the wrap turns out .
Kevin
1982 GL1100A
1982 GL1100A
- Buli
When i did my one and first wraps i did not read any instructions. So i did not use colwes and did not make that wrap wet. So i did swallow a lot glass dust and my hands was burning and ticled like..... Hopefully u did read
Kinde
- BikeMaine
I soaked this in water for 2 days and I wore gloves. It was a real pain.Buli wrote:When i did my one and first wraps i did not read any instructions. So i did not use colwes and did not make that wrap wet. So i did swallow a lot glass dust and my hands was burning and ticled like..... Hopefully u did read
I don't like the steel clamps that come with the wrap. Very difficult to get tight.
Kevin
1982 GL1100A
1982 GL1100A
- toolbox
Looks good! I was wondering how well those clamp things work...I'm wondering if there's some other clamp out there that would work well and look good. Worm clamps would be an obvious choice, but certainly lack something in the aesthetics department .BikeMaine wrote:I soaked this in water for 2 days and I wore gloves. It was a real pain.Buli wrote:When i did my one and first wraps i did not read any instructions. So i did not use colwes and did not make that wrap wet. So i did swallow a lot glass dust and my hands was burning and ticled like..... Hopefully u did read
On mine, I have to clamp the connection from the flex pipe to the HD muffler with a muffler clamp...I'm thinking I'll just use HD clamps and hide the wrap under that, but that still leaves the header end to tie off. If you come up with another solution, keep us posted...
No personal experience with pipe wrap but I have seen copper wire used and just twisted tight. It looked good and the twisted part can be concealed behind the pipes.
- Buli
- toolbox
Hmmm...I just might give that one a try...I was thinking about maybe using a few wraps of piano wire or something that wouldn't be noticeable, but that sounds like it would be easier and probably better looking.Easter wrote:No personal experience with pipe wrap but I have seen copper wire used and just twisted tight. It looked good and the twisted part can be concealed behind the pipes.
I've used the wrap with the supplied clamps with very good success.
- BikeMaine
I tend to over build and over tighten everything. I feel like I didn't get these tight enough, although they're staying where I left them..... I'm positive that I could get a standard plastic zip tie a whole lot tighter than these things. Maybe there's a trick to pulling them tight, I don't know. I've never used these before and no instructions of any kind came with them. After putting them on the pipe, I grabbed the tag end with vice groups and pulled while dad held the little lock from rising around the pipe with a flat screw driver.robin1731 wrote:I've used the wrap with the supplied clamps with very good success.
Is there a better way?
Kevin
1982 GL1100A
1982 GL1100A
- wheeliedog
I'm busy with a wrap too and gave up trying to get those stainless ties tight. They seem to slip a few mm before they bite so they end up just too loose for my liking.
I used thin stainless wire in the end. I like it, I think that's how it used to be done anyway....
- WingWrap.JPG (152.48 KiB) Viewed 77 times
