GL 1200 cafe (Te Racer) projekt.
- Hanslehoff
Re: GL 1200 cafe (Te Racer) projekt.
Great job! I wish I had your skills to build body panels, very impressive
1975 Cafe Wing
http://www.ngwclub.com/forum/viewtopic.php?f=16&t=56574
- Buli
Thanks.Hanslehoff wrote:Great job! I wish I had your skills to build body panels, very impressive
Kinde
Looks super!!
- Buli
Hey everybody. Apparently, now is the spring because I started servicing my bike again, compulsively. Last spring, the motorcycle had a problem with overheating because the radiator fan was broken. Soldering was oxidized and the fan did not always work. I repaired the fan but I wasn't quite happy with the repair. new found in CMSNL online shop but the price is about 450 € + shipping fee. I found a similar model in the chinese online store, with a price of € 60 including all charges. Manufacturer Part Number: 38616-PWA-J0. ( i think this is original HONDA part but not for GL 1200) But it wasn't exactly the same. So i needed to fix it. The collar around the bearing was larger than the original and the propeller did not fit so it need to cut smaller. Because the fan was a little bigger. About 6mm higher and wider. the mounting holes had to be enlarged. Fortunately, propeller mounting holes were on the right distance
- Left is original and at the right the new 6mm wider and higher
- IMG_20190429_132234.jpg (73.71 KiB) Viewed 293 times
- also the collar around the bearing was larger than the original
- IMG_20190429_132245.jpg (95.79 KiB) Viewed 293 times
- i used 60mm drill to cut the collar
- IMG_20190429_135529.jpg (175.49 KiB) Viewed 293 times
- collar done
- IMG_20190429_140850.jpg (120.43 KiB) Viewed 293 times
- the mounting holes had to be enlarged
- IMG_20190429_154919.jpg (113.29 KiB) Viewed 293 times
Kinde
- Buli
It looks quite good i think. I will paint the parts before i install it.
- IMG_20190429_154856.jpg (156.46 KiB) Viewed 293 times
Kinde
- Buli
The radiator and fan are painted and ready for use. I also made a new enrichment lever. I found an old fiberglass tent stick, which I used as a cable sleeve. As a cable i used 2 mm iron wire.
- IMG_20190511_162705.jpg (126.72 KiB) Viewed 260 times
- IMG_20190511_162856.jpg (89.77 KiB) Viewed 260 times
- IMG_20190511_162911.jpg (110.27 KiB) Viewed 260 times
Kinde
- Buli
After struggling for a long time against laziness, I decided to paint my bike. I bought a cheap spray gun (35 €) that seems to be good. I gonna paint with two colors and top with lacquer. It was about 30 years since I last painted it with a spray gun, so i dont know what to expect. here are a few pictures how it goes.
- IMG_20190516_193133.jpg (153.3 KiB) Viewed 235 times
- IMG-20190517-WA0005.jpg (243.61 KiB) Viewed 235 times
- IMG-20190517-WA0003.jpg (132.38 KiB) Viewed 235 times
- IMG_20190516_193120.jpg (118.27 KiB) Viewed 235 times
- IMG_20190517_175739.jpg (120.11 KiB) Viewed 235 times
Kinde
- Buli
It looks good so far. tomorrow i paint the lakka on the top. btw it took endless time to mask all stripes.
- IMG_20190518_223112.jpg (37.87 KiB) Viewed 222 times
Kinde
- Buli
some leak in mask. but i hope i can sand whit 600 paper this leak/error/stain a way. if not i just have to live whit it.
- IMG_20190518_222955_LI.jpg (38.25 KiB) Viewed 221 times
Kinde
Looking good! You have more courage than I do, tackling a paint project out in the yard.
especially with lacquerTrack T 2411 wrote:Looking good! You have more courage than I do, tackling a paint project out in the yard.
- Buli
I am so stupid. Last night i almost wet in my pants, so happy a was about the result of my painting work. but today morning I was not so happy. I went to the tent to make preparations for lacquering. Sanded the parts lightly whit sandig pad and. .. red color mixed slightly with white color. The red was not completely dry. Now I look forward to the evening and try to do wery sligt sandin whit water and water sandingpaper. If this is not working i just hafty re do the painting. grrrrrrrr
Kinde
- Buli
. Luckily I didn't mess up the tank, just the other parts.Buli wrote:I am so stupid. Last night i almost wet in my pants, so happy a was about the result of my painting work. but today morning I was not so happy. I went to the tent to make preparations for lacquering. Sanded the parts lightly whit sandig pad and. .. red color mixed slightly with white color. The red was not completely dry. Now I look forward to the evening and try to do wery sligt sandin whit water and water sandingpaper to remove the red stain. If this is not working i just hafty re do the painting. grrrrrrrr
Kinde
Bummer. I hope the wet sanding goes well.
- Buli
It was not so bad situation what i earlier was thinking. I am pretty sure i can fix paint problems. I let the parts dry untill tomorrw then i will spary the lacquer. This is how it looks now. I am very happy
- redwing.jpg (226.05 KiB) Viewed 185 times
Kinde
