- giphy.gif (692.73 KiB) Viewed 378 times
Buffet Racer: Propav8r's '78 GL1000
- propav8r
Re: Buffet Racer: Propav8r's '78 GL1000
I built a manometer last night...gonna sync the carbs this evening. I need to recheck timing too. It just kinda goes flat around 6500 and has a little misfiring at low RPM. Something's off, but it's been running well enough that I haven't bothered.
- propav8r
So I spent yesterday evening syncing carbs...I should've done this a long time ago. No idea why I didn't.
Here's before:
And after:
It idles so smoothly now. I also used to have a really annoying dead spot off idle, and when you were riding down the road and rolled on the throttle, you could hear 1 or 2 cylinders hanging low. That's all gone now. Idle is virtually perfect, and throttle response is smooth and linear.
Here's before:
And after:
- warhead_71
- My Album: https://www.ngwclub.com/gallery3/index. ... _71?page=2
Built mine the same way after watching some videos on YouTube. And it's actually even more accurate than using gauges... never needs calibrating.
- propav8r
We probably saw the same video. I didn't do the PVC pipe reservoir/airbreak thing, but its fine without it. I might add some in the future, but it's not a huge priority at the moment. Worked like a champ.
- desertrefugee
Dang, that does look accurate. I have a Carbtune that I bought 10 years or so ago and paid about $100 for it (as I recall). In 10 years, I have probably used it a dozen or so times. Not sure that was worth the $100 ... but it does fit into a drawer in the toolbox...
amazing how much better the multi carb bikes run when they're all sync'd huh??? so many problems cured by this fix.
nice looking sync gauge! I too have a carbtune, got an incredible deal on it ages ago and it works great, but before that, i used this method, and it worked perfectly!
- propav8r
Yeah, the gauge set me back about $25 all in. I cut a recess for those clear tubes on the table saw...I should've used that as an excuse to buy a dado blade.
I'm considering buying a Gunson Colortune too to dial in the mixture.
Nice call. I've always wanted one of those, but haven't had the need to buy one...
- propav8r
Out of curiosity, how much mileage do y'all generally get out of a rear tire, something like a Dunlop 404 or Shinko 230?
- wingrider
A buddy of mine that is a newer rider got about 4,xxx miles out of a 404...he wasn't riding that aggressive, as he was still new to riding. I do know the pressure was always at 41 psi cold.
This was on an 1100...
- desertrefugee
Currently about 4000 miles on a 430. Looks to be, maybe, half gone. '78 GL1
- propav8r
Interesting. I'm getting 3500-4000 out of the D404s and S203s I've been running on the back. I do live in the mountains though.
The bike has been running great. It'll weep a little bit of coolant out of the water pump sitting overnight after a ride, but not more than a couple drops. It's not worth taking it off the road quite yet...that'll be a winter project.
More than likely, I'll be pulling the motor back out this winter and investing some genuine effort on a paintjob. I'm not at all happy with the paint finish on the motor, and it really drags the look of the whole bike down.
- propav8r
Whelp, as the old-timers told me, it's not a question of if you go down, it's a question of when.
My when was about a week ago. I was leading a (car) cruise of about 30 people on a beautiful backroad out here. I had dusted the cars, and when I got to a straight section, I pulled up to let them catch up.
I was thinking about what was behind me instead of what was in front. I turned sorta side-saddle making sure the whole group was with me, and then gassed it as I turned around forward again.
Big mistake. I was farther along on the straight than I thought, and I had twisted the throttle about 30 yards before a sharp left hander.
I did the thing you're NEVER supposed to do, and fixated on a big gooseneck trailer on the outside of the turn.
Of course, I hit it. I overbraked, skidded, and went off the road. I got lucky enough to go underneath the arch of the goosneck, but the bike went down in the dirt at a fairly slow speed.
I was uninjured (because I was wearing full gear and a full face) and the bike is a little worse for wear.
Bent fork (at least the right, I'm replacing both just to be sure), tweaked wheel, and a little bit of broken fiberglass on the tail. No huge losses, and nothing a couple hundred bucks can't fix.
I rode the bike the rest of the day with a pretty decent wobble, but nothing too terrible. I didn't notice the tweaked fork til I got home.
So I've sourced a set of forks, a '79 Comstar front wheel which is going to powdercoat today, along with a couple other things. I'm still not sure if I need an axle or not. I should check that tonight...I think the triple tree is okay. I checked it with a straightedge and everything still looks lined up.
Glad it wasn't worse.
- 10 Replies
- 1450 Views
Last post by LastMohawk
- 114 Replies
- 12527 Views
Last post by CrazyJerry
- 19 Replies
- 4380 Views
Last post by wingrider
- 2 Replies
- 320 Views
Last post by Steevensi
- 15 Replies
- 1180 Views
Last post by Swedeflyer
