DEATHBYPIZZA's 1980 GL1100 Project.
So some of you may have seen my various questions on the forums which the answers helped a BUNCH!
so this first update will be just all photos, in a IMGR gallery as i dont want to flood this with photos.
if you have questions, tips, or input let me know!
so here goes!
http://imgur.com/a/Xuq18
so here goes!
1980 GL1100I (parts)
1978 GL1000
"I Have No Idea What I Am Doing."
1978 GL1000
Re: DEATHBYPIZZA's 1980 GL1100 Project.
thought i would add a picture of my rebuilt "plumbing"
and my new exhaust tips showed up!
1978 GL1000
1978 GL1000
Keep going.
came into a snag tonight while trying to take the left frame off for engine removal, all bolts came off except the one that is the bottom engine mount on the left near the starter.
the right side popped right out with a little push, this nothing. hiotting with a hammer even wont knock it loose.
the head of the hex bolt is slightly worn so getting my 17mm on it to stick is a little bit of an issue.
advice?
advice?
1978 GL1000
1978 GL1000
Just a WAG, is that jack stand maybe putting pressure on the motor/frame to cause it to bind? A lot of things work better when you wiggle them around a while. You'll know when you get older.
sometimes even wiggling doesn't work !
- chewy999
Depends how hard you wiggle!!!!!!
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
Current bikes
I knew that would start a conversation------- from all the old duffers. We're talking bolts.
I got the side frame to come off a little with no luck of moving the engine.
Meanwhile my resistor caps showed up along with my 10ft wire from lowbrow customs. So I made my plug wires!
1978 GL1000
1978 GL1000
- propav8r
I like those wires. Wish I had done something similar on my bike.
Thanks! They have nice colours at low brow. They sell 10ft for like 20$?propav8r wrote:I like those wires. Wish I had done something similar on my bike.
Got the caps on eBay for 10-15?
And I'm reusing the twist on tips from my old wires.
1978 GL1000
1978 GL1000
- propav8r
Yeah, I'll probably order some up. My Dyna coils use regular automotive boots and ends at the coil, and I'm also still using the screw-on resistor caps.deathbypizza wrote:Thanks! They have nice colours at low brow. They sell 10ft for like 20$?propav8r wrote:I like those wires. Wish I had done something similar on my bike.
So I gave up removing the engine and I've since painted it and such in the frame ha
Anywho here's a little update. Put the wheels on and ran the brake lines etc.
1978 GL1000
1978 GL1000
Looking good
Nice!
- 3 Replies
- 316 Views
Last post by Fred Camper
- 11 Replies
- 1389 Views
Last post by Docvan
- 6 Replies
- 495 Views
Last post by rcmatt007
