Swissitalian 1200 custom bike
Re: Swissitalian 1200 custom bike
I like the clip-ons and the rusty frame. I will try the first one. Thanks.
- duke182
Looking good
Keep us posted
Keep us posted
1984 1200 standard
click pic to see my gallery
vote in my poll
1984 1200 standard
vote in my poll
- Buli
I've cleared up and moved the solenoid and fusebox into the first aid box. Now they are together with a smal lithium battery. I'm thinking about an m.unit blue and eliminate the fuse box. I also want to lower the bike, unlinik the brake and put a clutch cable.
- 174551.jpg (111.16 KiB) Viewed 206 times
The only easy way to do a cable actuated clutch is if that's an '84 motor. If so, the early clutch cover will bolt right up. If not, it'll be a bit more challenging.
Ok, thanks. Mine is a 87 Model.
The solenoid is moved, the fuse box is eliminatet and the clips are on it. Can someone see the motoscope pro?
- IMG_3814.PNG (874.07 KiB) Viewed 187 times
- IMG_3815.PNG (973.79 KiB) Viewed 187 times
- IMG_3816.PNG (875.52 KiB) Viewed 187 times
Wow! The tank has been scalped!
You're certainly making great progress!
I got a cheap tank and try to weld it myself. Let's see how it is, otherwise I'll give it in order.
With shorter shocks, I now have a side stand problem.
The neu springs are perfekt, but without airsuspension I do not know how to close the small holes on the fork tubes. Any idea?
Whats your plans for the fuel tank?
The fork tops, I bought these for mine and Im pretty sure you have the same forks as I do, the antidive ones.
http://www.ebay.co.uk/itm/Black-CNC-Ano ... 3d2f2de5f2
I meant the small holes of the air suspension, not the fork cap. I would like to close the tank flat, so that I can make the seat like the red line in the picture bevor.
- 7 Replies
- 638 Views
Last post by BikeMaine
