General Patton
tlbranth
General Patton
Post #1 by tlbranth » Wed Feb 14, 2018 12:58 am
I bought this '75 from Pony Ruiz - a regular on NGW forums - in November 2012. I spent a while fixing problems, taking off all the dodads and making it into The General. My pictures are not too organized so I'll just post a few with comments as I find time and top it off with the final result.
Here's the bike as it was originally
Terry
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
desertrefugee
Re: General Patton
Post #2 by desertrefugee » Wed Feb 14, 2018 1:09 am
:popcornx2
Wow! Looked great "as was". It will be neat to see the progression.
'97 Valkyrie, '79 CBX-Z, '78 GL1000
"Motorcycling is not, of itself, inherently dangerous. It is, however, extremely unforgiving of inattention, ignorance, incompetence or stupidity." - Anonymous
Re: General Patton
Post #3 by CYBORG » Wed Feb 14, 2018 8:22 am
I agree, looks pretty good the way you got it
brianinpa
Re: General Patton
Post #4 by brianinpa » Wed Feb 14, 2018 8:49 am
Yup, this one should be good!
:popcornx2
Brian
ADC(AW) - US Navy Retired 1983-2003
If you aren't having fun doing it, find something else to do.
1984 Standard - 18,000 miles - Naked... the way it should be
1987 Interstate - 62,000 miles - Resurrected from the rust bucket
tlbranth
Re: General Patton
Post #5 by tlbranth » Wed Feb 14, 2018 1:58 pm
One of the big things I did was chuck the wiring harness and a lot of stuff attached to it. I used relays to cut down current going through most switches. I also wanted to add some safety features found on newer bikes - for example, prevent starting unless in neutral or clutch pulled and kill the engine if in gear and the kickstand is down.
I removed all the components on the left shelter side and cut out all the lumpy stuff so's I could get things flatter for my relays.
Things are quite tight inder the left cover so I made some mockups of fuse boxes and relays to see how to fit everything.
I patched in some sheet metal where I'd cut out the lumps.
My friend Peter pimped and painted for me. Note the hand-whittled 7v bracket on the left.
I cut out some 1/8" sheet ABS to go under the components. There are 2 welded ground bolts, one on each end.
Preliminary wiring in. No room for relay sockets so I wired directly. I'll post my final version of the wiring diagram at the end....if I remember.
Terry
1999 GL1500 SE
1970 CB750
tlbranth
Re: General Patton
Post #6 by tlbranth » Wed Feb 14, 2018 8:29 pm
Before taking the whole bike apart, I fitted several things that would require welding.
Bonneville peashooter mufflers get fitted.
Then I made a stop for the center stand
...and a locator for each rear footpeg
Terry
1999 GL1500 SE
1970 CB750
desertrefugee
Re: General Patton
Post #7 by desertrefugee » Wed Feb 14, 2018 10:46 pm
Mother McCree and General Jackson (except in this case it's Patton).
That's some serious love you're showing this machine. I love the direction. (And the metal skills).
tlbranth
Re: General Patton
Post #8 by tlbranth » Wed Feb 14, 2018 11:51 pm
I used a spare '75 clutch lever switch for the kickstand switch. It's a nice compact, sturdy switch and can still be had from Honda for $10 or so. I cut the stupid rubber thing off the kickstand. Positioning the switch was quite a deal. There are very few positions that are viable.
I made a new dash from sheet metal. This is to house a mechanical oil pressure gauge, a voltmeter, a couple of switches (on/off for the lights and hazard warning) and lots of indicator lights. Fitting this thing was quite a chore.
I wanted to add gaiters to the front forks and I wanted a more British looking headlight. So the fork ears had everything cut off except the fitting that held the position lights. I welded on tubing above and below this fitting to add these items
Pimping comes later
Terry
1999 GL1500 SE
1970 CB750
tlbranth
Re: General Patton
Post #9 by tlbranth » Thu Feb 15, 2018 12:10 am
Bike gets disassembled. I sent all the zinc plated nuts and bolts out for replating. I also disassembled both wheels and sent the spokes and nipples out to be plated. All the parts got blasted for painting.
here's the frame after blasting and pimping some of those nasty welds Honda does.
stuff blasted and awaiting paint
Hardware going out for plating
blasted and masked
Black paint
Terry
1999 GL1500 SE
1970 CB750
RAT
My Album: http://www.ngwclub.com/gallery/v/wingmans/rat/
Re: General Patton
Post #10 by RAT » Thu Feb 15, 2018 10:16 am
Serious work .... thanks for the excellent reporting ....
'82 GL1100 Interstate 'R2B5' (Rat 2 Be 5)
2001 ST1100 'R2B4' SOLD ....
Team 898, Team LTD 993 and Team '76 R2B3
My Original 'RAT' was an '82 CB900/1100F
Oldewing
Secretary
Secretary
Re: General Patton
Post #11 by Oldewing » Thu Feb 15, 2018 1:41 pm
Attention to detail is amazing........
I put fresh gas in the last one I did lolol
82 GL1100 Interstate-Oldewing (under going MAJOR work, fresh frame, NEW motor)
68 CB 350 Hiding in my shed, soon my darling soon........
06 GL1800 Comfort and Nav-Farkels(RAT rode it, and came back, THIS thing has too many Farkels)
82 QZ50R Wifeys bike
76 GL1000 Mostly RAT's but lives here....
This ain't no ordinary run of the mill motorsickle club!! action1 gltriker 2015
Re: General Patton
Post #12 by robin1731 » Thu Feb 15, 2018 4:54 pm
Oldewing wrote:Attention to detail is amazing........
:orange :orange anim-cheers1 anim-cheers1
1975 GL1000 parts bike (parts for sale)
Re: General Patton
Post #13 by HOTT » Thu Feb 15, 2018 5:06 pm
Go get 'em Terry ! action1 action1
Man! great foundation being laid there. tumb2
[quote]No room for relay sockets so I wired directly.[/quote]
Ahh, sockets are way over rated anyway :lol:
delling3
Re: General Patton
Post #14 by delling3 » Thu Feb 15, 2018 5:44 pm
I think this has the making of a BOTM. Nice work.
delling3
Currently Bikeless
Previous:
2006 Kawasaki Concours: Sold
sgwilly
Re: General Patton
Post #15 by sgwilly » Thu Feb 15, 2018 10:54 pm
Nice work!
Steve
'75 GL1000
'83 GL1100 MonkeyWing
'70 Suzuki T500 Titan
'99 Valkyrie Tourer
'64 MGB
'89 Isuzu Trooper 3.4L
IBA #58082
SGWilly Gallery
Who is online
Users browsing this forum: No registered users and 2 guests
