General Patton
- tlbranth
Re: General Patton
Well I have a pdf file of the wiring diagram but since I can't figure out how to load it on here I just took a photo of it. Any better ideas? It's not real easy to read. The original is 11 x 17 and is quite clear.
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Re: General Patton
That looks factory! Did you, essentially, restring the factory harness and accessories, but with the addition of the relays? Or did you completely re-invent the wheel? (Didn't look that closely at your schematic).
Re: General Patton
Photo is fine for me. It’s saved to my photos. Looks really doable.
- tlbranth
Re: General Patton
I reinvented the wheel. There's almost no original wiring on the bike.desertrefugee wrote:That looks factory! Did you, essentially, restring the factory harness and accessories, but with the addition of the relays? Or did you completely re-invent the wheel? (Didn't look that closely at your schematic).
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Re: General Patton
Actually, I knew you had pretty much replaced the OEM harness. I didn't phrase my question adequately. I looked closer at your schematic and answered my own question. Anwer = Yes. (Actually both. You added relays to the philosophical factory approach AND re-invented the wheel).
I was wondering if you'd stayed true to the OEM layout except adding relays to significant load circuits. You did. A very robust approach and one that will be easy on crimps and connectors on the service side of the relays. I like it. Lotta work, but quite a feat.
Re: General Patton
Very impressive work, beautifully done. Just hope those relays are reliable!
- tlbranth
Re: General Patton
I think (hope) the relays will prove reliable (Bosch/Tyco). I will carry a couple of spares though. I wired it so that there are no splices anywhere. All joinery is crimped at connectors. Also, all input and output goes through the left shelter so anything can be tested there. I got a copy of the wiring diagram laminated to go with the bike and I'll always have a multimeter along.
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Re: General Patton
I used a multitude of those relays 5 or 6 years ago, and have never had one fail. As used, they are almost indestructible, in my opinion
Re: General Patton
Most relays are rated in the 100's of thousands of cycles. It's difficult to wear out a relay in this type of application. Usually the failures are from vibration rather than excess current. I've used thousands of these over the years with a failure rate that's too low to worry about. Carrying a spare is easy, especially when you can't just buy one anywhere.
Addicted to Honda's
Addicted to Honda's
Re: General Patton
Super clean build.this should be good!
- HOTT
Re: General Patton
Well done!.
- BikeMaine
- lcallison
Re: General Patton
Awesome job! I really like what you did with the wiring harness.
Larry
84 GL1200A
79 GL1000
84 GL1200A
79 GL1000
- tlbranth
Re: General Patton
Thanks all for the encouraging comments. The bike runs great but some problems remain. Mileage is poor and I have a coolant leak and an oil leak. I'll work on those things and hope to ride it to Deadwood in August.
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Re: General Patton
It would be great to see it in deadwood. PS, can I beg a copy of the wiring diagram from you via email?
