Tyres
- codyjames707
Re: Tyres
I would imagine it would be just getting a tire that is below 140. 90 is for the width of the tire, 16 for the rim size, but the 140 is for how large the tire is from the rim. Good luck and keep us posted!
Re: Tyres
Several manufacturers list the 150/80-16, including Dunlop, Kenda, and Shinko. Whether or not it will fit without some modification to the swing arm is the next question...
Re: Tyres
So instead of a 140/90 you are looking for a 140/80 or even a 130/80 profile. First number is the tread width. Second number is the aspect ratio. a 140/90 is 140mm wide and the sidewall is 90% of 140mm. A 130/80 is 130 mm wide and the sidewall is 80% of that.
Re: Tyres
140/90 has a 126mm high sidewall
140/70 has a 98mm high sidewall
Metzeler makes a 140/70 16 but I have not seen a 140/80
Re: Tyres
Yea, just looking to see if I could fit a lower sidewall profile, im pretty sure itll look greatWhiskerfish wrote:So instead of a 140/90 you are looking for a 140/80 or even a 130/80 profile. First number is the tread width. Second number is the aspect ratio. a 140/90 is 140mm wide and the sidewall is 90% of 140mm. A 130/80 is 130 mm wide and the sidewall is 80% of that.
Re: Tyres
I do not know how wide the interstate rims are but on a stock 1000 rim I would be hesitant to go narrower and shorter at the same time esp on a tubeless application. If the stock manufacturer size is 140/90 I would be comfortable with reducing one of those numbers but not both. There are fitment charts out there that will tell you the safe sizes you can use but you need the rim size first.
- 6 Replies
- 246 Views
Last post by Steve81GL1100
- 15 Replies
- 497 Views
Last post by Old Fogey
- 10 Replies
- 352 Views
Last post by sphen
- 3 Replies
- 439 Views
Last post by pidjones
- 11 Replies
- 381 Views
Last post by Crazzy450z
