Anyone put a stereo on their GL1000?
- x01660
Hey, guys.
I've got a naked GL1000, wondering if anyone has mounted speakers/stereo on a naked 1000. Or if that's even possible without a fairing.
It's probably silly, but I'm wondering.
I always ride with headphones (I know, let the begin...) to cut down on the wind noise when I'm on a long ride.
Though it would be nice to have external music while I'm cruising around town.
But I don't want a fairing. At all. I like wind buffeting....
So, ideas, gents and gals?
-x01660
"The best motorcycle is the one well ridden"
"The individual has always had to struggle to keep from being overwhelmed by the tribe. If you try it, you will be lonely often, and sometimes frightened. But no price is too high to pay for the privilege of owning yourself." ~Friedrich Nietzsche
Re: Anyone put a stereo on their GL1000?
I have seen lot's of set ups for this, mostly speakers (weatherproof ) hung from the bars and radio tucked away in a nook some wheres. I ride with a gent that has a V-Star with this set up, looks kinda busy but works well.
You can also get Bluetooth speakers, and/ or amp...
- x01660
Ive seen a few of those handlebar setups, which I think are perfect.
My only issue is the charging system; can a GL1000 charging system actually power a stereo like that?
-x01660
- dontwantapickle
To me the answer is obvious, just keep using the headphones.x01660 wrote: I always ride with headphones.....................
- x01660
Its what I do, and on the freeway (or when I'm in the middle of nowhere) its fine. But drivers around here are TERRIBLE, and it would help to be able to hear them a bit more clearly.dontwantapickle wrote:To me the answer is obvious, just keep using the headphones.x01660 wrote: I always ride with headphones.....................
-x01660
- gregforesi
I've got a 100 watt amp stuck in the glovebox, speakers mounted to the headlight bolts, and an old ipod on a ram mount at the clutch perch. The bike is fairly loud so mostly, over about 45, it's just white noise. Works for me though.
2006 GL1800 (Brutus Maximus)
- heath1066
- Zinc Member
I got a couple of speakers on the handlebars, amp under the seat, Ram Mount for phone. And like everyone else, over 45 you can't hear it...
Heath Hays
Chicago, IL
Chicago, IL
- x01660
Ok, so two of you have 100 watt amps. Think the charging system can handle a 300 watt system?
-x01660
- heath1066
- Zinc Member
It'll be more important to get efficient speakers and insure you have proper headroom in your amp than it will be to up your wattage. Look for speakers with a high sensitivity, and look for digital amps that are a bit more efficient with power than older designs.
Heath Hays
Chicago, IL
Chicago, IL
- gregforesi
And LED turn indicator bulbs, and tailight bulb, and the "always on" dash bulbs will free up some wattage for other things. The stator puts out about 300 watts and (7) seven watt incandescent dashlights (even in Detroit schools) comes out at 49. LED replacements are 1.5 to 2watts each.
- x01660
Is there a thread somewhere that lists the specific bulbs on a 78? That way I can make one order? I've been wanting to do that for a while. Even the cluster lights.gregforesi wrote:And LED turn indicator bulbs, and tailight bulb, and the "always on" dash bulbs will free up some wattage for other things. The stator puts out about 300 watts and (7) seven watt incandescent dashlights (even in Detroit schools) comes out at 49. LED replacements are 1.5 to 2watts each.
-x01660
- 173 Views
Last post by BikeMaine
- 3 Replies
- 3669 Views
Last post by Graham Cracker
- 249 Views
Last post by jdvorchak
- 301 Views
Last post by Sidecar Bob
