1985 GL1200 Limited, time for a new project.
Wolfie666
Re: 1985 GL1200 Limited, time for a new project.
#91
Post by Wolfie666 »
Wiring the handlebars...
second gauge, low fuel, low oil, and gear indicator.
Don't take life seriously,
You will never get out alive!
Wolfie666
#92
Post by Wolfie666 »
Making the RAM GPS mount fit its new home.
Gauges mounted.
Wolfie666
#93
Post by Wolfie666 »
fuel pump and parts.
Now to sort out the Weber's
#94
Wolfie666 wrote:Wiring the handlebars...
One color of wire for everything?
Wolfie666
#95
Post by Wolfie666 »
No, that's the sleeve, 4 wires in each small one, and 9 in another and 15 in tha last.
#96
Ahhh, good. ;) anim-cheers1
#97
Wow! Those gauges look awesome...
#98
:2thumbs :2thumbs :2thumbs :2thumbs
Wolfie666
#99
Post by Wolfie666 »
Track T 2411 wrote:Wow! Those gauges look awesome...
I actually spent the past few months figuring that out, I bought a bunch of different cases, and even 3D printed a bunch of cases before finally coming up with the HD Turn Signal housings.
bigscheaf
#100
Post by bigscheaf »
Okay, the work on the gauges has to be one of the coolest parts of this project. Gorgeous work with the paint, too. I think that red is deep enough to have the full bike that color.
Never really thought of creating a setup like that for gauges and now yours is the second I've seen on the interwebs. I think the other guy still has some programming to do. Happen to have some resources for the Arduino setup? I probably wouldn't want to tackle anything like that this summer, but maybe during the winter when there's 5 feet of snow on the ground.
1983 GL1100 viewtopic.php?f=16&t=67673#
1981 CB900F (Resto-mod Project)
1979 CB750F (Wiseco 823)
Wolfie666
#101
Post by Wolfie666 »
bigscheaf wrote:Okay, the work on the gauges has to be one of the coolest parts of this project. Gorgeous work with the paint, too. I think that red is deep enough to have the full bike that color.
I'm not a programmer by day, so I wouldn't mind sharing the full program, and even giving some assistance with converting it to a different display, as the display I am using is not readily available.
bigscheaf
#102
Post by bigscheaf »
Wolfie666 wrote:I'm not a programmer by day, so I wouldn't mind sharing the full program, and even giving some assistance with converting it to a different display, as the display I am using is not readily available.
That would be awesome! And no worries, I’m not a programmer by day either, but I can be dangerous.
I’ll have to dig on cb1100f.net and see if I can find the other post. Might be able to share some additional insight from the inline 4 side of the house. Should be fairly similar between the two platforms for the speedometer and tachometer.
DUGG
#103
Post by DUGG »
The all white wires remind me of the color coding for the old air cooled VW fuel injection, all the wires for the fuel injection were, white that’s how you knew they were for the fuel injection. No trace colors.
Really enjoying this build and I’m looking forward to the finished ride
Wolfie666
#104
Post by Wolfie666 »
bigscheaf wrote: That would be awesome! And no worries, I’m not a programmer by day either, but I can be dangerous.
there are 330 lines of code, if you PM me your email address I will send it to you.
Wolfie666
#105
Post by Wolfie666 »
Switchbox, RF (remote) Standby power, Ignition Bypass, Timing 4 Curve Switch, Digital Dash Display Switch.
and... a few more wires...
