1985 GL1200 Limited, time for a new project.
Re: 1985 GL1200 Limited, time for a new project.
Post #16 by robin1731 » Fri Aug 24, 2018 9:54 am
Looks good so far.
You know you can out more than one picture in a post. ;)
1975 GL1000 parts bike (parts for sale)
Wolfie666
Post #17 by Wolfie666 » Fri Aug 24, 2018 10:46 am
No, going to use dual Webers.
Don't take life seriously,
You will never get out alive!
Wolfie666
Post #18 by Wolfie666 » Fri Aug 24, 2018 10:53 am
With the lights.
-The fender is a "Twisted Choppers" 7 x 16 that I sectioned to fit the 150/90 15 Avon Venom Tire.
Wolfie666
Post #19 by Wolfie666 » Fri Aug 24, 2018 11:04 am
The electrics tray, radiator catch tank, and the upper front engine mount and partial shield (to keep the heat from the carter fuel pump which will sit directly behind it.)
and maybe the battery box...
Wolfie666
Post #20 by Wolfie666 » Sun Aug 26, 2018 7:45 pm
Tacked up the exhaust...
Modified the air scoops from an 1100, moved the 1200 tank forward to make room for the
Mustang early sportster seat. Had to cut back on the turning radius of the forks.
Still have to open up the rear of the "tank" so the seat fits inside...
codyjames707
Post #21 by codyjames707 » Tue Aug 28, 2018 3:27 pm
Man, this is looking like a quick build with good quality! Keep it moving! Are you moving the air filter for the carbs to the outside of the frame??
1977 Gl1000 DARKGREEN-WING
BOTM April, 2018
https://ngwclub.com/forum/viewtopic.php?f=16&t=59710
Wolfie666
Post #22 by Wolfie666 » Thu Aug 30, 2018 11:02 am
codyjames707 wrote:Man, this is looking like a quick build with good quality! Keep it moving! Are you moving the air filter for the carbs to the outside of the frame??
Using dual Webers.
BikeMaine
Post #23 by BikeMaine » Wed Sep 19, 2018 10:42 am
When I first saw your rear fender welded before the primer, I thought it wasn't going to look good at all, but then the photo with it all primed changed my opinion completely. Very nice.
And Welcome to the Forum!
Kevin
1982 GL1100A
codyjames707
Post #24 by codyjames707 » Wed Sep 19, 2018 1:54 pm
Looking forward to seeing more progress!
BOTM April, 2018
Wolfie666
Post #25 by Wolfie666 » Wed Sep 19, 2018 3:20 pm
I did the rear fender like that so there wasn't so much space between fender and bags.
Progress as of today, getting ready for paint.
Wolfie666
Post #26 by Wolfie666 » Sat Sep 22, 2018 11:10 am
Imitation Tank ready for paint
Wolfie666
Post #27 by Wolfie666 » Wed Oct 10, 2018 7:28 pm
Little progress...
Post #28 by Track T 2411 » Wed Oct 10, 2018 7:52 pm
That be red! lolol lolol lolol Gonna look good!
BikeMaine
Post #29 by BikeMaine » Thu Oct 11, 2018 12:14 pm
I'm looking forward to seeing this put together.
Kevin
1982 GL1100A
Wolfie666
Post #30 by Wolfie666 » Thu Oct 11, 2018 12:45 pm
Waiting on paint for the tins, frame and the engine.
Working on some of the electrics. I use Motogadget's M-Units for all my bikes,
and that makes it simple... But I can't leave anything alone so getting carried away with electrics...
Who is online
