11 out of 10
Re: 11 out of 10
:oops:
BiKenG
Re: 11 out of 10
Post by BiKenG »
ericheath wrote:Final Drive Unit
You beat me to it Eric. :-D
Sorry for any confusion. I normally try to only use any abbreviation after I've already declared the full name within the same post, but that might have slipped in without me noticing. I blame Christmas :)
Ken
You can't have too many bikes
RIP: cookie
Re: 11 out of 10
Has often been called a 'differential' ....
Gord(by others)Jones anim-cheers1
BiKenG
Re: 11 out of 10
Post by BiKenG »
RAT wrote:Has often been called a 'differential' ....
Which as we know is totally incorrect. Pumpkin is another term and is about as factually accurate. :)
Ken
Re: 11 out of 10
Well Honda calls it "final Drive ", so that works for me
BiKenG
Re: 11 out of 10
Post by BiKenG »
Maybe this forum could provide a 'Glossary' where we can register such common abbreviations so anyone can reference that to understand exactly what is being discussed. I certainly find myself puzzling sometimes over an unfamiliar and unqualified abbreviation that has been used. Something like this would help.
Ken
Re: 11 out of 10
I always thought a differential meant a final unit that compensated for the differing speeds needed in the two rear wheels in a turn
BiKenG
Re: 11 out of 10
Post by BiKenG »
rcmatt007 wrote:I always thought a differential meant a final unit that compensated for the differing speeds needed in the two rear wheels in a turn
That is correct. That's exactly what it means.
Ken
Re: 11 out of 10
the "differential" is the "different" speeds needed
RIP: cookie
Re: 11 out of 10
I didn’t say it was a correct description ....
Gord anim-cheers1
