Aftermarket front master cylinder
- Tin Member
Hello all,
Proud new GW owner from Cape Cod MA.
Converting an 83 Aspencade to a Cafe.
Is anyone aware of an aftermarket front master cylinder, preferably with a remote reservoir, that works well with the original linked brakes?
I’d like something that is smaller in overall size bc it’ll be mounted to clip-ons.
- Zinc Member
Re: Aftermarket front master cylinder
You may be able to find something with a similar piston size from another bike. Some sport bike masters are pretty good.
Do you plan to maintain the linked brakes? I am currently doing an 83 with un-linked brakes (have done this before), no particular reason other than simplicity and ease of installing stainless lines. I am in the process of installing the front master cylinder. An inexpensive Chinese kit with separate reservoir and matching clutch. I haven't connected it yet but the quality seems quite good. It comes partially disassembled and doesn't include instructions so assembly was challenging but so far so good. The cable receiver/adjuster on the clutch perch had to be replaced with one for a larger cable but fortunately I had one available and the mounting threads are the same as stock. (see Red Belly build thread.)
A partial follow-up: I am still happy with the quality of these units but bleeding them has proven to be a real challenge. Mostly because it is difficult to position the MC so that the air bubbles can flow up all the way from the calipers. The angle of my bars (clip-ons) combined with the curvy hose of the remote reservoir work to trap the air in the lines. I am using two lines with a double banjo at the MC. But I finally got them mostly bled. The bike is on the table still so I will come back to the brakes later. It will be a while before I can test them.
- Tin Member
Thank you for the info. I will probably un-link mine bc they just feel lousy! I’ll most likely use a double banjo on one caliper, and thereby be able to use a shorter hose to go caliper to caliper. Then add a single shorter hose to the double banjo to mc. I think this will give me less hose over all vs 2 hoses on mc. May be easier to bleed, and have better feel.
What is the bore size of your master?
My experience with the Chinese master is to take it apart, clean it thoroughly and reassemble it properly (with brake fluid lubricating everything) before putting fluid in it.
- Tin Member
Any more specific info on the Chinese MC?
Brand, model, supplier, etc.
Here is a photo of the unit mounted on my bike. There is a matching clutch. "Black 7/8" CNC Motorcycle Front Brake Clutch Master Cylinder Lever Set Reservoir" The dealer on ebay was neverland-usa. $26.39 for the pair. Free shipping even.
- 004 (11).jpg (111.25 KiB) Viewed 411 times
- gdonlo04
is this ebay item number 173677899996?
It appears to be the same thing. If I recall, I did have to switch the adjuster on the clutch perch for a larger size to fit the GL cable. I happened to have one in my spares.
- codyjames707
I have this one on my bike, easy fit, lower than the other one. You can usually find it on ebay or any of those other places
I've used the ones above on 2 bikes now with success. I just ordered a set for the 1200 I picked up.
1975 Honda Goldwing GL1000 (café project, started Oct 2018)
1978 Honda CB400T Hawk II (son's project)
1980 Honda CB750C Café
1986 Honda Goldwing GL1200 stock dresser
- Zinc Member
When you replace master cylinders or clutch levers that don't have mirror perches, you can get replacement handlebar clamps that include a perch. Suzuki part number 59671-32F00 is one that works. You can also get similar units on amazon/ebay/aliexpress - search for Motorcycle 7/8"(22mm) Handle Bar Rearview Mirror Mount Holder Clamp Adaptor.
82 GL1100 Standard 44k miles 83 wheels & forks
Get the 5/8" or 16mm piston units to handle the dual front/unified (83 onward) calipers. And, probably best to replace all lines along with rebuilding the calipers. Since you'll need shorter lines, consider custom building your own with the Goodridge system.
- 4 Replies
- 233 Views
Last post by drfrank01
- 24 Replies
- 773 Views
Last post by tlbranth
- 13 Replies
- 626 Views
Last post by pidjones
- 11 Replies
- 336 Views
Last post by Toehead
- 13 Replies
- 551 Views
Last post by Sidecar Bob
