Monoshock
- Lead Member
Monoshock
Hi Guys, got myself another GL1100 . Its an 80 to basically play around with and my minds set on going monoshock. Done a search through the forum but not much comes up on the subject, which i'm very surprised about. One build that i did manage to find was called KRBobber from 2009. This is pretty much what i'm after except i'll be keeping the stock carbs and removing all the back frame.
1st question is, does anybody know what rear shock he used on this build. Seems like all the other info is there except that one important bit.
Re: Monoshock
Look up "'raptor" built by CYBORG
- Lead Member
Re: Monoshock
I've tried that and get basically nothing except you telling some other bloke you're dismantling it.
You say there's a write up of the build but I can't find that anywhere either.
- RIP: cookie
Re: Monoshock
Scroll all the way to the bottom of the page ....
Gord(similar threads)Jones
- Lead Member
Re: Monoshock
Still don't really find anything on "Raptor" . Found out its a Virago shock but nowt else.
Plus it doesn't answer my actual question on the KRBobber shock.
- RIP: cookie
Re: Monoshock
viewtopic.php?f=16&t=23444&start=90&hilit=raptor
Heres the original thread .... unfortunately the pics have been highjacked
Re: Monoshock
Mine rode awesome using a Suzuki M109 monoshock. It did have a lot of travel and would hit the seat sometimes with the wife on back. Trying to make it better and add the pro-links I screwed something up and wrecked it. Ended up going with straight 1100 shocks set back a bit for a lower ride.
I have pics buried somewhere.
- EA3A7EAA-5361-4E99-BFE3-34E236EC2C36.jpeg (224.66 KiB) Viewed 363 times
- B983F3D4-FEB0-4153-9539-BA33320A5F28.png (236.08 KiB) Viewed 363 times
- Barrie
Re: Monoshock
ericheath wrote:
The 1000 can be twisted with bear hands.
1976 Gran' Luxe 1000. Once red, now orange, soon yellow...
- Lead Member
Re: Monoshock
And !
Re: Monoshock
Not a problem,..... unless you want to turn
Re: Monoshock
I didn’t mean to attach the second and third pics.
- Lead Member
Re: Monoshock
That's OK, I kinda realised they had nothing to do with the subject.
Still nobody seems to know anything about the shock on the KR Bobber. I've bought one off a Fazer 1000 now. See how that works...or not
Re: Monoshock
Any mono shock from the same weight bike, and installed correct, should work
- Lead Member
Re: Monoshock
Thats what i was kinda thinking. Its all in the engineering
- Lead Member
Re: Monoshock
And so it begins
https://youtu.be/s8A30AuphVQ
