Page 1 of 2
Anyone mount a fog light like this?
Posted: Mon Jul 27, 2020 12:34 am
by cmyoch
I saw this online today. I like the look, especially mounted to the crash bar. Anyone do something similar to this? If so, what light and especially what was used as a stable mount?
- 4F743C20-551A-4E9D-BCA1-8F2D1761A4EC.jpeg (157.25 KiB) Viewed 509 times
- 7E39F513-CE85-4585-9BE4-77ED2BA2AE9B.jpeg (128.26 KiB) Viewed 509 times
Re: Anyone mount a fog light like this?
Posted: Mon Jul 27, 2020 12:11 pm
by ritalz
https://stlouis.craigslist.org/mpo/d/ar ... 40239.html
I was looking at these lights for the new bike. LED with a decent price and the look like they will fit the openings I have. May have to fabricate a bracket but that's ok.
Posted: Mon Jul 27, 2020 12:29 pm
by cmyoch
My main concern is the bracketry to attach to the round bar and not make it look too home-made.
Posted: Mon Jul 27, 2020 2:20 pm
by sgwilly
I have driving lamps mounted on my crash bars. Simple round pipe clamps. That's all easy enough and a solid mount for many years and miles.
- Screen Shot 2020-07-27 at 2.12.34 PM.png (413.3 KiB) Viewed 483 times
If you're looking to replicate what this fellow has done - apparently bolting directly into the round bar - good luck. I don't see that as being viable over time as it will weaken the bar as well as be difficult as heck to actually implement what with the little material in the crash bar to thread and the need to exactly match the curve of the mounting bracket to the bar. I see a wiggly light unless extensive custom work is implemented. As in a solid crash bar.
Posted: Mon Jul 27, 2020 3:27 pm
by cmyoch
I'd prefer not to drill directly into the bar if possible. I assume you are talking about a clamp like this?
- Wrought-Steel-Pipe-Clamp-3-4-Awning-Hardware_1.jpg (32.61 KiB) Viewed 478 times
I would use the post from the light to tighten the clamp.
Posted: Mon Jul 27, 2020 3:57 pm
by sgwilly
Actually something more like this. But there’s a wide range of clamps out there.
- D5E27C6E-F77E-42A5-84B2-CBB8DC734420.png (298.66 KiB) Viewed 476 times
Posted: Mon Jul 27, 2020 4:30 pm
by cmyoch
That is a much cleaner clamp.
Posted: Mon Jul 27, 2020 4:53 pm
by sgwilly
Yeah, but be careful. I just grabbed that image quickly. The clamps I actually used are much wider and stouter in general. I'd worry that those thin ones wouldn't be up to the job.
Here's a link.
https://www.ebay.com/itm/Motorcycle-Foo ... 1663987938
Kurykin also makes an expensive version.
https://www.ebay.com/itm/Kuryakyn-1-1-8 ... 2346421838
Posted: Mon Jul 27, 2020 5:42 pm
by ob1quixote
I clamp things to round bar all the time! Look at the attachment brackets for Bark Busters. I trust mine when riding in the woods to hit saplings intentionally. Well yeah, maybe I should have said "used to", been a while!
There are simpler and more robust mounts with the cheaper models. Just have to measure the pipe on the guards amd start looking!
Posted: Thu Jul 30, 2020 2:18 pm
by 230Rocket
So here's the best couple of shots I could find of the set up on my '82 GL1100. The lights are the widely available Cree 3000 LEDs and come with the solid anodized aluminum bracketry that simply bolts around the crash bar, it even had a small rubber gasket to protect the bar coating.
The lights work really well, either as daytime running lights dipped to not dazzle, or driving lights suitably adjusted for night time running.
cheers
Dean
Posted: Thu Jul 30, 2020 6:04 pm
by cmyoch
Did that light come with the bracket or did you buy that separately?
Posted: Fri Jul 31, 2020 9:50 pm
by 230Rocket
It came with the brackets.
Posted: Tue Aug 31, 2021 1:47 pm
by digschopper
Lol,I just did the same thing with an el cheapo rectangular one I had left over. It's mate met it's demise on a curb,mounted under- bumper on my mustang. Waste not want not.
Posted: Tue Aug 31, 2021 2:32 pm
by 5speed
my mounts came on my 82. they are made from flat bar wrapped around in a u shape with the "top" leg longer then the bottom one and the end of it is bent at a slight angle.
the lights are spot light in the middle and floods on the end leds.
Posted: Mon Sep 06, 2021 3:45 pm
by heraldhamster
this is what I did just a month or so ago:
- IMG_20210906_124101.jpg (188.37 KiB) Viewed 325 times
- IMG_20210906_124129.jpg (189.26 KiB) Viewed 325 times
pay no attention to the bugs. haven't been able to bathe her since I got home from Deadwood.
the round bar mounting brackets didn't come "with" the driving lights, but came in the same order from the same Co. from which I bought the lights.
