79 GL1000 Cafe Racer Build
wannabridin
Re: 79 GL1000 Cafe Racer Build
Post by wannabridin »
pidjones wrote: Mon May 24, 2021 6:33 am Have you decided to restore or restomod? While the front is off for the pump is a good time to pull the neutral switch and run it through the ulltrasonic cleaner or just replace. Also pull the cover off the sump on the right side, the oil pickup, and clean the bottom of the sump.
Don't forget to throw on shorter bolts for future removal ease while in frame.
Also, while engines out, if the budget allows, a hydraulic clutch can be had to help make shifter more consistent.
Custom79
Brass Member
Brass Member
Post by Custom79 »
wannabridin wrote: Tue Jun 01, 2021 12:42 am
Does the hydraulic clutch mod make a big difference? I was searching it a bit but mostly found folks trying to work out problems with it. (maybe it was just my search or I didn't go far enough) If it is worth it, I would definitely be open to doing that as well!
wannabridin
I have no reference frame for it, but if it's anything like my other old japanese bikes, finding neutral when hot can be a challenge. A hyd clutch eliminates that. Mine feels great for the 5ish miles Ive put on it, hahahaha
Gowing
Post by Gowing »
Looking forward to more posts. Going great.
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2(Blaze)
wingrider
#20
Post by wingrider »
Custom79 wrote: Sat Jun 05, 2021 11:54 pm
Here is Oldfogey’s take on the clutch mod…. Fitting hydraulic GL1200 clutch into GL1000.
