But really, this guy is really talking up this intake mod that I was unaware of, anyone have real world HP numbers to show this is a legit mod? More curious What is the intended purpose of these tubes? Emissions?
https://youtu.be/roDnXSRiYpY
6yr old trick to huge power!!
- Lead Member
If it hasn’t broken yet, there is more HP left in the tank.
- Lucien Harpress
Re: 6yr old trick to huge power!!
Guy's blowing smoke up somebody's butt- either somebody else's, or his own. My KZ1300 had a similar setup- literally all it does is add clean air to the exhaust gases after combustion to help hit emissions standards. Heck, it injects the air into the headers, past the exhaust valves, so any air that goes through that system doesn't even make it into the combustion chamber at any point.
Now, does it hurt anything to remove it? Not really. It eliminates a couple potential failure points, but that's it. But as far as adding power? Complete malarkey.
The author in the vid may have had a huge increase in power because his stock secondary air system was faulty to begin with. Hence, his bike was sub-standard to begin with. Lots have removed the air system. Most I have read of and the set I did resulted in no noticeable change in performance. Mine did cause more backfiring when down shifting and closing the throttle.
I think that is the case in many of these situations. Go ahead and spend hundreds and hundreds on this new an improved gizmo rather than spending a few bucks to fix the original system. Of course it runs better it was basically broken when you started.
- 2801 Views
Last post by Rat
- 1 Replies
- 1450 Views
Last post by sparkyrasmus
- 2583 Views
Last post by 77Gowing
- 6 Replies
- 749 Views
Last post by duke182
- 19 Replies
- 840 Views
Last post by scootsx2
