1200 thermostat-crossover part?
Looking for a number for a 1200 thermostat. Lots of numbers in the cross reference link, but none state for a 1200. Does anyone know if they all interchange?
Re: 1200 thermostat-crossover part?
On page 9 or ten in the crossover parts list, I did find some numbers that will work. Checking Honda parts fiche, the 1200 has a different part number than 1000/1100's.
441Victor
Post by 441Victor »
The correct thermostat is STANT # 13958
It is slightly larger on the OD from the 1000/1100
Mine came with a brass rivited check valve on the plate . I just cut it off with a side cutter.
Make sure to mount it with this small bleed hole on top .
The spring side goes toward the engine ( toward the back of the bike )
60 Yamaha, 68 BSA 441 , 66 BSA 650 Lightning ,72 CB500, 77 GL1000,87 Aspencade
