7V Regulator
Moderators: robin1731, RAT, Forum Moderators
RIP: 1950-2011
Re: 7V Regulator
Post #31 by Cookie » Mon Sep 06, 2010 4:23 pm
I was putting a piece of aluminum strip on for cooling and then potting them in various containers, no problems heard of.
Dave_J
Re: 7V Regulator
Post #32 by Dave_J » Mon Jan 10, 2011 3:04 am
There is not a need for the capacitors for voltage balencing. And 99.9% of the time when one of these transistor based regulators fail, they go open and you have no output. But the old Points regulators can fail closed and then 12 Volts do hit the gages.
A LM317 is a nice Chip regulator. By changing the risistors values you can make a 12 volt battery charger for solar panels that output 18V to 30V DC. By bridging them you can get over 10 AMPs of output. I have build a few solar powered battery banked backup units.
Retired US ARMY Signal
Old Mopars TT 65 B-Cuda in the works, 78 Dodge LRT with 425 HP 360
80 GL-1100 Faux Interstate
03 Suzuki Burgman 650 Supersized Scooter - Darksided Potenza Car Tire on the rear
muncher9707
Re: 7V Regulator
Post #33 by muncher9707 » Sun May 06, 2012 8:54 pm
I think I will just spend the money and stay OEM on this part, the gas gaguse showsmfull when I know it isn't and the temp gauge is stuck on H whe I know it is not HOT.
Re: 7V Regulator
Post #34 by robin1731 » Mon May 07, 2012 7:40 am
muncher9707 wrote:I think I will just spend the money and stay OEM on this part, the gas gaguse showsmfull when I know it isn't and the temp gauge is stuck on H whe I know it is not HOT.
I'm not sure you can get new OEM anymore. And used one's would be hit and miss on working. I have gotten some from an ebay seller called roberth9. They work very well and price isn't bad.
muncher9707
Re: 7V Regulator
Post #35 by muncher9707 » Mon May 07, 2012 8:31 pm
Too far gone from stock but it works. I will concentrate on my cooling system instead.
muncher9707
Re: 7V Regulator
Post #36 by muncher9707 » Tue May 08, 2012 6:56 am
The gas and temp gage do not work properly but I can live with those for now. I knew that when I bought it.
vintwing
Re: 7V Regulator
Post #37 by vintwing » Fri Jul 13, 2012 5:27 pm
Thanks to everyone for the great info. I would never have figured out the problem, let alone the solution to the 2 gauges both failing. I went with torgo's solution of the mouser part. Very inexpensive solution, and I can say it works great, with no extra resistors or other stuff to assemble. Very good for those of us with only moderate electrical skills. This was easy for me! Mouser was great to deal with, even to Canada, I recieved my package in a week using the least expensive USPS option, total cost including shipping was about $12. It's soooo nice to have those gauges working again!
1975 GL1000 Antares red Nanaimo BC Canada
triwing
Brass Member
Brass Member
Re: 7V Regulator
Post #38 by triwing » Tue Aug 11, 2015 5:19 pm
Just acquired some 7volt regulators from Mouser, (#BA17807T's) & have a question, does it need to be mounted to a heat sink of some sort for cooling? Or will it generate enough heat to be a factor?
triwing
Brass Member
Brass Member
Re: 7V Regulator
Post #39 by triwing » Tue Sep 15, 2015 6:46 pm
Finally got around to making up a couple for my two 84 standards, as the trial one with not as nice a solder job has been working great. ;) Very pleased with the updated version, nicer solder job, plus a second piece of shrink wrap, to cover the pieces on each leg of the regulator. :lol: Looks pretty nice, & really appreciate the input about this, shakehands called to see if needed a heat sink of any kind & was told not at all, not much heat generated here. crossy.gif
guidowitz
Re: 7V Regulator
Post #40 by guidowitz » Tue Sep 15, 2015 7:27 pm
David
Dept of Veterans Affairs...(Retired, 1985-2014).
1976 GL 1000 (current ride)
Previous rides:
1971 Triumph Bonneville
1966 Harley "FL" Police Bike
1951 Triumph Thunderbird
Sandy
Re: 7V Regulator
Post #41 by Sandy » Thu Sep 17, 2015 7:03 am
Sandy
1974 Honda XL350
1975 Red GL1000 (gone from stable but still in the family)
1976 (original owner in 76) Sulpher Yellow GL1000
1977 Restored then Triked Sulpher Yellow GL1000
1976 (garage find completed 2015) Sulpher Yellow GL1000
1978 Watsonian Monaco
1960 IH B414
http://www.flickr.com/photos/76_gl1000_project
triwing
Brass Member
Brass Member
Re: 7V Regulator
Post #42 by triwing » Sat Sep 19, 2015 10:39 am
Could not bring myself to pay $40 X 2, :IDTS: when 3 solder joints on each one, shrink wrap, & crimp connectors, on end of wires to plug in & your done, ;) for WAY LESS than $40. crossy.gif
OldRider2
Re: 7V Regulator
Post #43 by OldRider2 » Sun Jun 10, 2018 6:56 am
Another source for the 7V regulator is Murray's Carbs. SidecarBob helped me with the link and info. Very good price, 1/2 what the other option was, $20 +$3 shipping. It is professionally packed into a plastic case with epoxy or something similar sealing it all up. Good price, fast shipping, and better yet I didn't have to do a bunch of soldering and remanufacturing the old one. I just had to change the terminal ends and it plugged right into the electrical system of the bike. I had a couple of questions after I got the regulator and Murray was quite responsive in answering me.
https://murrayscarbs.com/product/7-volt-regulator/
1977 GL1000 (Project almost done. Almost is relative!)
2001 GL1800 Ilusion Red
Who is online
