Page 1 of 3
7V Regulator
Posted: Sun Nov 16, 2008 3:00 am
by purplegoldwing
Here is another option for a 7V regulator that is working for me. I have about 300 miles on this now so far with no problems.
It is from Dimension Engineering. I just velcroed it in place.
I purchased their breakout board to mount it on. Makes wiring it in easier.
http://www.dimensionengineering.com/DE-SWADJ.htm
Posted: Sun Nov 16, 2008 3:12 am
by sunnbobb
OK, i need an explanation...
Posted: Sun Nov 16, 2008 12:56 pm
by purplegoldwing
This replaced the 7 volt gauge regulator on my GL1000. The fuel and temperature gauges use 7 VDC instead of 12VDC to insure accuracy and stability. That way the gauges always have a constant voltage instead of fluctuating with battery voltage. Otherwise the gauges would typically drop at idle when the stator voltage dropped.
Uses three wires just like the original. Just have to wire it in directly instead of using the original plug. Just has three wires, battery voltage, ground and the output to the gauges.
This is mounted behind the left door/panel of the fake tank.
Posted: Sun Nov 16, 2008 1:41 pm
by purplegoldwing
Here is a picture of it in place. Note the high tech Velcro mount.
Posted: Sun Nov 16, 2008 2:07 pm
by sunnbobb
What is the picture in the upper right showing the regulator mounted on a board next to something?
Posted: Sun Nov 16, 2008 7:45 pm
by FirstYearDeek
Top left, first post is the finished package. Top right is the transistor they use, then the transistor on the board with the other components required to adjust the voltage.
Middle left and right are different views of the finished package.
Bottom left is a "breakout" board with a (very funky) 3-pole socket for the transistor. Bottom right is the package in the socket for a finished product that's easy to wire.
It's all a little "un-engineered" for me, but I like to pot stuff and would probably find a way to water-cool it or something!
-Deek
Posted: Sun Nov 16, 2008 8:16 pm
by purplegoldwing
keeping it simple keeps the cost down, the regulator is only $15
Posted: Sun Jan 11, 2009 12:07 am
by hiddenone
thanks for the info! :-D
Posted: Sun Jan 11, 2009 2:41 am
by Cookie
It looks like a tough little unit.
Posted: Mon Apr 27, 2009 3:32 pm
by hallcm83
going to have to try that on mine finicky temp readings and gas gauge is way too inconsistant
Posted: Mon Apr 27, 2009 5:22 pm
by purplegoldwing
It's been installed for awhile now and is still working. Noticed you are from Tyler Texas, I used to live there back in the late 70's. Is it still called the Rose Capital?
Posted: Tue Apr 28, 2009 4:48 am
by hallcm83
Oh yeah still the Rose Capital it has gotten alot bigger but there are some great rides along this part of Texas.
Posted: Mon May 04, 2009 9:11 pm
by Mike Toon
Satisfied it worked, I gutted the old regulator and used epoxy putty to fill and hold things together. Installed back in stock place.
I had the parts, but bought at Radio Shack, about $3.00
Posted: Thu May 07, 2009 11:58 pm
by purplegoldwing
How did you get the old epoxy out? I tried that and destroyed the case.
That old epoxy is hard!
Posted: Fri May 08, 2009 2:25 am
by Mike Toon
Drill press, drill press vice, gloves and a lot of patience.
