fork guru failing,brakes dont fit
Finally got a good set that rebuilt,cleaned up polished real nice. everything going great untill the brake caliper wont bolt up,spaceing is different, I never noticed. DAMIT I wonder what I have? I need some brakets,hoses, and calipers? for? my 1976 gold is wingless frt brake less. supose i could just run with rear brake only,na probably not.
76 gl naked, runs good, always tinkering
79 gl all the fairing stuff gone, work-in-progress
68 chevelle hi compression fat block, OH YA! In process of changing gear ratios, I'm excited!
73 tahiti jet 455 olds sweet heart, sad in a way, she gone, traded for a VTX Honda, didn't like it , traded For a Harley 19 Road King Classic, Stage 2, OH YA
- roncar
Re: fork guru failing,brakes dont fit
Pics would help. Sounds like you have 78/79 forks. If so I think you will have issues with the rotors and calipers lining up. Pics and some measurements here..... http://www.ngwclub.com/forum/viewtopic. ... 2543#92543boogie red wrote:...the brake caliper wont bolt up,spaceing is different, I never noticed. DAMIT I wonder what I have?....
need caliper brakets,hoses for 78-79 will 76 calipers work s
Those pics were helpful,I have the braket holes that are spaced closer together,so may be 78-79 forks,so will the 76 calipers work in the 78-79 brakets,brake hoses long enough? I am useing spoke wheels. Thanks
- roncar
The 76 calipers and brake lines will work fine on 78-9 forks and caliper mounts. the problem is the rotors on the wheels. The comstar rotors are closer together and the fork/mount is setup to center on them. When used with the wire spoke wheels, something (grinding?) will have to be done to the mount/fork to get the mount further away from the wheel and line up on the rotor. Sounds like work to me.
beat it to fit paint to match ( grinding)
ya its all work,just gettin frustrated,I suppose I could try and find another set,I had already been through 2 sets, bent tubes,sliders shot,I think I am going to try and find the caliper brakets that go to these forks and see just see,beat it to fit paint it to match( grinding) would be feasable. Thanks Hopefully it doesnt become FUBARED
