Page 1 of 1
here is a great fitting ford starter sol.
Posted: Wed May 26, 2010 10:11 am
by jpfrk
this starter sol. fits great under the left lid ,,a little filing of the two in. hole ,,slip it in from the air filter side,,one bolt to hold it ,,,gives aplace to hook up your coil "hot shot",,for great starting,,,stock air filter fits back fine.
Re: here is a great fitting ford starter sol.
Posted: Wed May 26, 2010 10:19 am
by sunnbobb
Cool, what's the cost on that little puppy?
Can you share a pic of it installed?
Posted: Wed May 26, 2010 11:51 am
by jpfrk
I believe this can be bought at autozone for $9.99,,thier PN is F491
by jpfrk
I will try to p[ost photo ,,later
Posted: Wed May 26, 2010 1:13 pm
by Rat
"gives aplace to hook up your coil "hot shot",,for great starting,,,stock air filter fits back fine."
What's a "Hot Shot" :roll:
Gord (Still learnin') Jones :oops:
Posted: Wed May 26, 2010 4:18 pm
by jpfrk
"Hot shot",,giving your ign system full voltage while cranking the engine,,the engine normally runs on reduced voltage because of resistors,,makes starting better
Posted: Wed May 26, 2010 8:13 pm
by jpfrk
here it is from the inside
Posted: Wed May 26, 2010 8:15 pm
by jpfrk
here it is from the front,,this is used on a totally rewired 75
Posted: Wed May 26, 2010 10:44 pm
by sunnbobb
nice, and thanks!!
