Janis lives!
Re: Janis lives!
They've got them on Amazon plenty cheap. I've used them plenty of times on other projects, and they've worked fine. Pressure is good and flow rate is plenty. The only thing is I really like the looks of the stock pump.
Re: Janis lives!
There are threads on replacing the stock pump diapragm. A quick summary is here: https://www.ngwclub.com/forum/viewtopic.php?t=9967 Also, 1000 (1100 fit too) pumps come up on ebay. Still very old, though. What I haven't seen a fix for is the pump's check valves which seem to be phenolic.
Re: Janis lives!
The pressure is 2.5 to 4 psi. The flow states 70 LPH.
Re: Janis lives!
Dropping the seat off tomorrow. Got a lady at work that does a pretty good job on reupholstering. Was thinking about going a little shorter, but I think I'll just have her do it in stock configuration.
Re: Janis lives!
Pulled the seat, installed new rear brake pads. I was going to tag her when I got the seat back, because it think I'll wait until spring. The I'll have the forks rebuilt by then. Any suggestions on fluid?
Re: Janis lives!
I just use synthetic auto trans fluid.
- Lucien Harpress
Re: Janis lives!
I think I've run ATF on every set of forks I've rebuilt. Never had any complains. Heck, the manual recommends it for the GL1200.
Re: Janis lives!
That's what I'll do then. Time to order seals.
Re: Janis lives!
Just make sure the tubes are slick, no dings or rust (rust is actually worse than dings).
- 14 Replies
- 657 Views
Last post by pidjones
- 19 Replies
- 1312 Views
Last post by Kingpin06
- 4 Replies
- 371 Views
- 4 Replies
- 322 Views
Last post by Whiskerfish
