Ethans GL1100 custom build.
- jimmyz3286
My 12 yr old son just tore down his future 81 GL1100 standard and is going to do some custom work on it and I would like to show off what he is doing.
- Day 1 of teardown.
- IMG_20130619_162737_856.jpg (75.26 KiB) Viewed 775 times
1982 GL1100 Silverback
2004 Roadstar For Sale
Re: Is this where I would start a build thread?
jimmyz3286 wrote:My 12 yr old son just tore down his future 81 GL1100 standard and is going to do some custom work on it and I would like to show off what he is doing. Is this the forum or should I start a thread on another forum?
Here ya go:
http://www.ngwclub.com/forum/viewforum.php?f=30
1977 GL1000
1978 GL1000
1979 GL1000
1978 GL1000
1979 GL1000
- Sagebrush
Moved this to the correct forum. Tell your son good luck with the project
He's going to learn a lot, and so will you. It will be a rewarding journey for both of you.
Now you can change the subject line. Just edit the first post to do that.
- jimmyz3286
Re: Ethans GL1100 custom build.
Thanks guys. When we get home I will get up to date.
- BigDub
Well Done ETHAN!
Ethan's Dad is an AWESOME DAD!
well done fellas! keep the good stuff coming!
here's a look at one of my builds:
http://www.ngwclub.com/forum/viewtopic.php?f=30&t=47596
1984 VF1100 Flat Black Saber
1981 GL1100 Flat Black Bagged aka my pickup
1976 MR175 farm/trail bike
1975 GL1000 Antares Red
- jimmyz3286
Ok we are home from vacation for a few days so I can update where he is at.
- This is what he got to start with I got this one for free. The exhaust is rusted off head gasket leaking I believe due to color and viscosity of oil and hadn't been ran since maybe '04. It did start with ether and run on gas that I added to the rusty tank. So he does have a starter bike.
- IMG_20130513_133441_807.jpg (104.96 KiB) Viewed 691 times
- Day one complete he got the front end torn apart. Given this is the first time he has EVER done any work on anything. my bike and sunnbobb's is giving him the inspiration.
- IMG_20130619_171606_128.jpg (62.22 KiB) Viewed 691 times
- Back tire off and tank out. He is getting the picture of what makes these tick and what makes us bike lovers tick.
- IMG_20130622_154800_392.jpg (96.41 KiB) Viewed 691 times
- Swing arm off, final drive off, radiator out only thing left is the engine and tree.
- IMG_20130624_182838_925.jpg (95.66 KiB) Viewed 691 times
- Everything but the tree is off and the engine isn't torn down but you can see his mind racing. This is his bench and cabinet. As he gets it cleaned, buffed, and sand blasted it will go into an enclosed storage closet till final prep and assy.
- IMG_20130625_123509_480.jpg (89.73 KiB) Viewed 691 times
Being the star wars expert he is, if he signs up on the site i might suggest this avatar for him:
- ethan.jpg (29.19 KiB) Viewed 688 times
- jimmyz3286
He said he got signed and his user name is Anakin, go figure.
- Anakin
- Rusty Probie
Sunnbobb, I got it changed. I'll post here updates with my build. The avatar picture was a bit big so I scaled it down.
1981 GL1100 Standard
- Sagebrush
Good job Anakin . That's telling Sunbobb how to do it. I did a similar thing with my grandson a few years ago on an 1100. They are great bikes. Make sure you replace the timing belts before running that engine as these are interference engines and if one of those old belts breaks then its destroyed valves and maybe pistons and rods as well. Not a good scenario. New belts are cheap insurance.Anakin wrote:Sunnbobb, I got it changed. I'll post here updates with my build. The avatar picture was a bit big so I scaled it down.
To see my grandson's 1100 build click the 1100 build thread link in my signature.
PS I hope you bagged and tagged all your parts and bolts as you took the bike apart. It sure makes reassembling it a lot easier if you did.
Anakin, I'm impressed. Keep up the good work, I'm looking forward to see your end result!
This will be an interesting thread to watch.
Sure looks like a great bike to build, nice actually that it was not dressed yet based on the missing headlight it had been a fairing bike?
Good to see you here!!!
