Pedro!'s rebuilding projects
Great to hear you are back!
I hauled one home a couple of years ago after seeing Pedro's, so far it is just sitting. I just can't seem to get my sandblast tank to feed properly. just keeps plugging up from the humidity. Have tried a bunch of different things and I can sort of get it to work if I shake the tank with one hand while sand blasting with the other but it is more trouble than it is worth so far.DocRoot wrote:Love the sandblast cabinet... those poly totes are available around here pretty cheap after their service for food transport then a second life for sap collection in maple sugaring... the third life as a sandblast tent looks promising!
I'm no expert on this, but what are you using for media? Is it dry to begin with? I've heard of folks using play sand, and that is strongly discouraged as it is silica and leads to silicosis. It is also very wet and clumps. In our blast cabinet at work we used either glass bead (I hated it as it shatters and makes glass dust that hangs in the air, gets everywhere, lacerates your lungs and sinus.) At home and as a preferred media at work was aluminum oxide - cuts fast and is very reusable. YMMVEaster wrote:DocRoot wrote:Have tried a bunch of different things and I can sort of get it to work if I shake the tank with one hand while sand blasting with the other but it is more trouble than it is worth so far.
Glass beads
- Pedrotq
G'day to Everyone!
I put on just a smell under a stone, lost most of it now (good)
I will be getting the car tyre rim offset so there is equal distance both sides of the tyre, have to wait until the funds are available first.
I spent today looking over the 75 and seeing where I was up to, did some wiring, fitted the headlight, indicators all round and the tail light.
Back to Telfer tomorrow morning for another fun week in the heat and flies.
All the best to all, Peter.
- 101_0950.JPG (250.86 KiB) Viewed 440 times
- 101_0951.JPG (274.13 KiB) Viewed 440 times
Perth, Western Australia.
is it humidity or moisture from your compressor?Easter wrote: I hauled one home a couple of years ago after seeing Pedro's, so far it is just sitting. I just can't seem to get my sandblast tank to feed properly. just keeps plugging up from the humidity. Have tried a bunch of different things and I can sort of get it to work if I shake the tank with one hand while sand blasting with the other but it is more trouble than it is worth so far.
- Patriccio
Import a twelve-year-old child from Mumbai, India at fourteen cents a day to shake the sandblast tank as you use the sand-
blaster. Should do the trick.
Who is this that darkens counsel
By words without knowledge?????
Couldn’t resist.
Couldn’t resist.
Sorry, didn't mean to hijack the thread (but Pedro has gone back to work anyway so he won't notice.)
- Pedrotq
Yes I will!
Pedrotq wrote:Yes I will!
- BikeMaine
Great work Pedro!
For Easter, if it's plugging your blaster, try a larger orifice in the nozzle, or, as 5-speed said, could be moisture in your compressor. But I'm betting you already have a water separator on your air hose??
Kevin
1982 GL1100A
1982 GL1100A
Yes, water separator. I have a pressurized media tank and the problem is in the tank, not at the orifice. Have tried a multitude of media over the last couple years. Have a similar problem with my soda blaster.
- BikeMaine
Sorry, my only experience is with a cabinet type blaster.Easter wrote:Yes, water separator. I have a pressurized media tank and the problem is in the tank, not at the orifice. Have tried a multitude of media over the last couple years. Have a similar problem with my soda blaster.
Kevin
1982 GL1100A
1982 GL1100A
- Pedrotq
G'day Everyone!
Another warm week in Telfer, the lowest maximum was 44C this past week
made up some new plug leads for my 75, took the plastic cap and insert from the old 1500 coils and glued a couple of "O" rings on, cut them to length, pushed an Awl into the ends and screwed them in place. Just have to cut them to length and fit the new plug caps on.
Been messing with the wiring to remove the ballast resistor and the diode that is in the starter circuit as I don't need them any more.
Hope to have more to show as the week goes on.
Happy and safe riding to all, Peter.
- put a smear of glue between the "O" rings and use the caps to push them together.
- 101_0952.JPG (303.68 KiB) Viewed 350 times
- All glued on.
- 101_0953.JPG (313.78 KiB) Viewed 350 times
- Cut the inserted end to length, awl the end to assist in fitting, then screw them on.
- 101_0954.JPG (327.14 KiB) Viewed 350 times
- 31 Replies
- 1966 Views
Last post by gltriker
- 11 Replies
- 1386 Views
Last post by heraldhamster
- 36 Replies
- 1125 Views
Last post by Fred Camper
