DeltaWing Build
Sandy
DeltaWing Build
Post #1 by Sandy » Mon Aug 08, 2016 3:39 pm
Inspired by the exploits of
gltriker; “Maybe I'll call it Threedom”
and
transitman; “Making a Trike”
I have decided to take the sage advice of ericheath and attempt to
“start planning your trike build now so it’s done before your 75.”
Having completed my 76 with Watsonian sidecar in 2010
Most recent 76 build completed 2015,
leaves me with a 77 “frankenbuild” completed in 2013 that would be a good candidate for a bolt on trike accessory.
This then will be my very slow built thread for the DeltaWing 1000, completion date unknown.
RAT
My Album: http://www.ngwclub.com/gallery/v/wingmans/rat/
Re: DeltaWing Build
Post #2 by RAT » Mon Aug 08, 2016 4:18 pm
Before you're 75 ....
Gord (I got 3 months) Jones
'82 GL1100 Interstate 'R2B5' (Rat 2 Be 5)
1984 GL 1200 Standard 'R2B4' SOLD ....
Team 898, Team LTD 993 and Team '76 R2B3
My Original 'RAT' was an '82 CB900/1100F
Re: DeltaWing Build
Post #3 by gltriker » Mon Aug 08, 2016 4:31 pm
http://www.ngwclub.com/forum/page/ST :oldies
https://www.youtube.com/watch?v=FVpommgI-M8 turn up your speakers volume YouTube video from April 12th, 2014
Sandy
Re: DeltaWing Build
Post #4 by Sandy » Mon Aug 08, 2016 4:52 pm
So it's to the bench for the 77.
Back end off so we can begin.
Purchased a more robust swing arm and drive shaft from a GL1100, pulled the bearing and machined a bushing.
Sandy
1974 Honda XL350
1975 Red GL1000 (gone from stable but still in the family)
1976 (original owner in 76) Sulpher Yellow GL1000
1977 Restored then Triked Sulpher Yellow GL1000
1976 (garage find completed 2015) Sulpher Yellow GL1000
1978 Watsonian Monaco
1960 IH B414
http://www.flickr.com/photos/76_gl1000_project
Re: DeltaWing Build
Post #5 by ericheath » Mon Aug 08, 2016 5:16 pm
Gord, you can do it, but if you don't need to, ride on. I sure hope I can still ride at 75, like lots of you guys.
I'm asking Sandy for close ups of the bushing, but he's probably arranging it as I type.
Sandy
Re: DeltaWing Build
Post #6 by Sandy » Mon Aug 08, 2016 5:58 pm
ericheath wrote:I'm asking Sandy for close ups of the bushing, but he's probably arranging it as I type.
Eric:
I didn't take too many pictures of the bushing.
Suffice to say it's just a hard bronze donut stuffed in the swingarm hole.
Tight fit.
I did drill out material behind the bushing so the 77 pivot bolt could go through.
Sandy
Re: DeltaWing Build
Post #7 by Sandy » Mon Aug 08, 2016 7:04 pm
Purchased a used GM S10 differential from local auto wrecker.
After dismantle and a good clean up it needed to be cut down to a size more in keeping with a trike.
I decided to remove 13" from the right side and 7" from the left would center the unit to the driveshaft of the Honda. Removing the material from the center of the axle tubes to maintain the axle bearing races.
Same amount of material was removed from the axles then the ends machined, welded and trued.
Sandy
Re: DeltaWing Build
Post #8 by Sandy » Mon Aug 08, 2016 9:23 pm
Now I have to join the GM differential to the Honda drive shaft.
Thanks to Cyborg and Rat I acquired a sacrificial drive unit that donated its pinion shaft and joint to the project.
To join the two, I cut the GM yoke and and used only the splined coupling.
Then manufactured an adapter to hold the Honda pinion joint.
Sandy
Re: DeltaWing Build
Post #9 by Sandy » Mon Aug 08, 2016 9:44 pm
Manufactured a coupling to join the S10 differential to the Honda Ddiveshaft tunnel of the swing arm.
This unit is in 2 halves, one bolts to the driveshaft tunnel and the other must be welded to the S10 differential.
The two pieces will then be bolted together encasing the GM/Honda yoke adapter.
Easter
Re: DeltaWing Build
Post #10 by Easter » Mon Aug 08, 2016 10:29 pm
I'm hooked, lets see more.
80 GL1100 Interstate: Now a Cafe Racer called DRAGON WING.
81 GL1100 collecting dust with about 300,000 miles, known as BLACK BEAUTY
2008 (I think) GL1800 Nice bike but as exciting as the family sedan!
76 GL1100 yes, 1100 with 1000 heads and cams, being customized
A fleet of parts bikes awaiting resuscitation or customization or abandonment :IDTS:
Oldboy
Re: DeltaWing Build
Post #11 by Oldboy » Tue Aug 09, 2016 6:12 am
Cool, nice work!
Cheers...
Just Wing-it :crosso
82aspy
Re: DeltaWing Build
Post #12 by 82aspy » Tue Aug 09, 2016 7:48 am
ngw quotes anim-cheers1 - \ "I will strip the beast" \ "the swingarm is just a hunk of metal" \ "gonna maybe ...dunno yet" \ "It's never done, thats the fun." \ "something about this site brings me back"
5speed
Re: DeltaWing Build
Post #13 by 5speed » Tue Aug 09, 2016 10:20 am
you people with your darn lathes, milling machines, water jets, cnc machines. :evil:
:mrgreen:
1982 1100 std.
2002 Shadow American Classic (the boss's ride) SOLD
Easter
Re: DeltaWing Build
Post #14 by Easter » Tue Aug 09, 2016 10:27 am
Feel the same way (jealous) thought I was uptown when I got the Battery powered DeWalt impact.
Sandy
Re: DeltaWing Build
Post #15 by Sandy » Tue Aug 09, 2016 10:53 am
5speed wrote:you people with your darn lathes, milling machines, water jets, cnc machines. :evil:
:mrgreen:
Sorry but I have to clarify:
My machinist buddy just retired and has all the machines necessary to do this work, so although I'm the design / engineer / apprentise, it's TZ and his machines that are making the parts I'm needing.
This project would not be practical cost wise if not for TZ's shop.
Same is happening now with some welding. Although I have an arc welder in my shop and will do most of the welding, I'm taking the critical pieces to a professional weld shop. I'm just not confident enough that my welding would be what I want holding the important parts together at hwy speed.
Sandy
1974 Honda XL350
1960 IH B414
Who is online
