Oh ya....RAT wrote:That's not the way I do it .... I take it over to your place ....CYBORG wrote:that's the way to solve the problems
Diamond in the Rough: My 75 Goldwing
Re: Diamond in the Rough: My 75 Goldwing
- BigBrian27
Here's an odd one for you guys.
I went to test the neutral safety switch this morning and with the bike in neutral, the switch has continuity to the frame like it should. With the bike in gear, there is no continuity. This tells me that the switch is operating correctly as it should.
When I tested the switch I unplugged the connector from the main harness and tested it.
These electrical gremlins keep getting stranger and stranger.
1975 Honda GL1000 Goldwing
1992 Kawasaki Concours ZG1000
Solid rotors suck! I have the PDF for the rotor drilling template, PM me if you would like a copy.
- BigBrian27
My wiring nightmare has only gotten more confusing.
Got both turn signals to work but only when 1 is hooked up reverse and it doesn't act as a marker light and it doesn't blink as fast as the other.
Then the headlight works but high beam is actually low beam and low beam is high beam.
Then the neutral light is on but when I check continuity on the switch itself, it's open like it should be and the rest of the wiring isn't shorted to ground but yet the light is always on.
And the kill switch is completely reversed but switching the wires makes nothing work.
So I removed the start switch and jumpered 2 connections for the start button which should only work when the kill switch is on run but it works all the time even with the rest of the wiring for the right hand switch disconnected.
I am so beyond frustrated. I have no idea what is causing my issues. All my grounds are good.
I do not know what to try.
Just be happy knowing you'll get it figured out, but if like me, you still won't understand 'lectricity. I think I recall the same issues as you describe. Keep guessing and checking unless you have a diagram.
- Patriccio
I took the Puppy to a shop & paid lots of money for an expert to work out the electrical "ishoooes."
I counted over one hundred wires emanating from the wiring harness & environs. My brain can't acquire, can't adapt, can't accommodate, that many "things." Plus, I had some beer to consume.
- BigBrian27
I do have a diagram but it doesn't appear to match my harness 100%. That is unless, of course, I am reading it incorrectly.ericheath wrote:Just be happy knowing you'll get it figured out, but if like me, you still won't understand 'lectricity. I think I recall the same issues as you describe. Keep guessing and checking unless you have a diagram.
- BigBrian27
I thought about that but the "lots of money" thing really turned me off...Patriccio wrote:I took the Puppy to a shop & paid lots of money for an expert to work out the electrical "ishoooes."
- BigBrian27
All electrical issues remedied!
It was a combination of an aftermarket, non oem style start switch and dirty connnections in the left hand switch.
Glad that's all figured out!
- BigBrian27
Very slow goings here. I lost my job unexpectedly which of course dried up all funds for the GL1000.
I have a few interviews tomorroe so I hope something pans out.
Hang in there. Most of us have been thru the same thing. You will come out the other side in better shape, and wondering why you didn't change jobs a long time ago
- Patriccio
Bummer.
- BigBrian27
Much appreciated, I had a job interview yesterday so things are looking up.CYBORG wrote:Hang in there. Most of us have been thru the same thing. You will come out the other side in better shape, and wondering why you didn't change jobs a long time ago
- BigBrian27
Good news! I got a better paying job. Work will commence on the bike shortly!
Cliff (74yrs )
Great! One door closes,....another opens
- 14 Replies
- 555 Views
Last post by rcmatt007
- 1 Replies
- 202 Views
Last post by Track T 2411
- 9 Replies
- 554 Views
Last post by WalterM817@aol.com
- 27 Replies
- 1459 Views
Last post by lcallison
