The next 1975 restoration
Irishman1
Re: The next 1975 restoration
Post by Irishman1 »
Installed original points and condenser. Got her timed but waiting for new throttle cables and choke cable. Took a break to get ruthe's yellow 75 carbs rebuilt and back on. Also had to give a quick clean up and ride of my newest addition to the hoard, 1979 CBX. Back to the gl and got her off the rack and fueled up. Next on the resto rack is the other sulfur yellow 76!! But first a move up the beach to our new shop with a great house!! Got 5he 81 restored to stock spec, repaired duct taped hole in the right front of fairing
My 81 cbx and my newest orphan, 1979 cbx with 13,000 miles
Ruthe's yellow 75 on the rack to clean and rebuild the carbs, paint the engine too
Cleaned and painted front brake splitter
The blue 75 off the rack for good. A few more details left
In the garage:
1975 Honda gl1000 sulfur yellow( my first!) NGW BOTM February 2020
1975 Honda gl1000 red (Ruth's free bike) NGW BOTM January 2017
1975 honda gl1000 red. Eariest of my 75's 2/75 date
1975 Honda gl1000 blue green 5/75
1975 Honda gl1000 blue green 3/75
1975 Honda gl1000 blue green 4/75
1976 Honda gl1000 sulfur yellow
1977 honda gl1000 red black, Ian's next bike
1976 Honda gl1000 red next restoration
1975 Honda cb750 rebuilding soon!
1975 Honda gl1000 2/75 blue/green
1978 Honda cb750f super sport
1979 Honda cb750f super sport
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
"I really need a BIGGER garage!!"
"I got a bigger garage!!!!
" ride'm, don't hide'm!!!
Irishman1
Post by Irishman1 »
Almost done with the blue 75 now another break to move up the beach! Finally and big shop to play in!!
New shop with a house too!! Still on the water as well!!! Lucky Irish
In the garage:
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
desertrefugee
Post by desertrefugee »
Now we know where all the nice, collectible early GL's have gone!
:shock:
Looking fantastic!
wingrider
#20
Post by wingrider »
Great collection!
bottona
Zinc Member
Zinc Member
#21
Post by bottona »
Really nice job! Hope you're recovering well!
Cheers, Albert
Irishman1
#22
Post by Irishman1 »
Well I’m back at it with the blue 75. Between my knee, shoulder, moving and sick or injured dogs, I’ve neglected my other babies. Got the brakes rebuilt. Clutch and clutch seals replaced ignition restored. Also restored the charging/starting system restored to original. Next is to restore the gauges and then small details. Then it’s on to the other red 75.
Cutting out burnt stator wiring
New connectors.
New connectors.
Crimped and soldered
Connectors in place
Connectors in place
Extra protection
Extra protection
In the garage:
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
Irishman1
#23
Post by Irishman1 »
More work. Restoring the exhaust(did it two years ago but installed on another bike), Found the clutch engagement pin seal leaking so I replaced the seals and installed new Barnett disks. Clutch back together at this time. .Small details going back together
Old, leaking cutch coming out
Another view. The rear clutch pin seal needs to be replaced along with Barnett plates
Back together
Back together
In the garage:
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
Irishman1
#24
Post by Irishman1 »
With the exhaust off it’s time to remove the center stand and restore the pivot and hardware.had already painted parts when everything was apart. Nice to be re-installing parts. Also repainted rear disc and replaced bolts/nuts
Center stand refresh
Rear disc refresh, OEM nuts and bolts
In the garage:
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
Irishman1
#25
Post by Irishman1 »
Battery reinstalled without the old wiring mess. Much better
Old, butchered main fuse wiring
Cutting out and cleaning up
Nice and tidy.i will replace main red wiring later to look better
In the garage:
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
Irishman1
#26
Post by Irishman1 »
Getting closer now. A few parts to put back together, small details then restore the gauges and put in the lineup for riding with the other gl’s. Then it’s on to reassemble the next red 75!
Going back together.
Partial line up. Minus the 5 under construction
The next red 75 waiting patiently
OEM detail parts
OEM detail parts
In the garage:
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
Irishman1
#27
Post by Irishman1 »
Got the exhaust refinished and starting on the gauge restoration. I get my gauges faces from cb750faces.com. I’ve used the “decal” type and these which are thick, solid plastic like the oemfaces
After sanding and repainting muffler
Another shot of refinish muffler. The headers are pretty good but I’ll repaint them later
The before muffler condition
Gauges before starting
In the garage:
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
Irishman1
#28
Post by Irishman1 »
Continuing the gauge restoration with new face plates. Taking the gauges apart
The tee shirt and hose clamp installed
The crimp rings look good but I do have replacement ones just in case(from cb750faces.com)
All apart. The rubber seal is loose making the case look bent. It’s ok and will be re-glued later
The tee shirt keeps the ring and gauge from being scratched
See the small screwdriver under the ring at a angle and prying the lip of the ring against the tightened hose clamp. This keeps the crimp ring from deforming
In the garage:
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
#29
Nice work on that gauge. hanks for sharing the technique. Guess I'm going to have to stop by your shop more often, but every time I do, I come away feeling guilty about how messy mine is!! LOL
Irishman1
#30
Post by Irishman1 »
Starting to reassemble the gauge’s. Cleaned and lubed, painted and treated with anti fog on the inside of the glass
Ready to go back together
In the garage:
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
