Let the party begin. Couple of 76 GL1000s
Re: Let the party begin. Couple of 76 GL1000s
My take is that if the oil is not changed often enough, or the bike sits a long time without running, or the wrong oil is used, the starter clutch rollers stick. The hole being drilled allows you to clean/lube the rollers. I feel that drilling a hole into a closed oil area will create a place for dirt and water to enter the system. Use the right oil, change it often, and run the bike from time to time,....and a hole is not needed
- palepainter
- Zinc Member
That may be true. But a little access wont hurt. The access bolt is flush with inside of case and there is no place for dirt to collect. The bolt is sealed with Teflon washer and wont allow oil out or anything in.CYBORG wrote:My take is that if the oil is not changed often enough, or the bike sits a long time without running, or the wrong oil is used, the starter clutch rollers stick. The hole being drilled allows you to clean/lube the rollers. I feel that drilling a hole into a closed oil area will create a place for dirt and water to enter the system. Use the right oil, change it often, and run the bike from time to time,....and a hole is not needed
Looks great.
First I've seen mention of a washer. But I have owned my 78 since it was almost new, and I have not had that problem. But I have taken apart engines that had flat rollers in the starter clutch, and obvious signs of poor maintenance ......just haven't experienced it my selfpalepainter wrote:That may be true. But a little access wont hurt. The access bolt is flush with inside of case and there is no place for dirt to collect. The bolt is sealed with Teflon washer and wont allow oil out or anything in.CYBORG wrote:My take is that if the oil is not changed often enough, or the bike sits a long time without running, or the wrong oil is used, the starter clutch rollers stick. The hole being drilled allows you to clean/lube the rollers. I feel that drilling a hole into a closed oil area will create a place for dirt and water to enter the system. Use the right oil, change it often, and run the bike from time to time,....and a hole is not needed
- palepainter
- Zinc Member
Probably should have mentioned it, but I felt that fell into the painfully obvious category. Since I was putting flat bottom bolt on a convex surface and all.CYBORG wrote:First I've seen mention of a washer. But I have owned my 78 since it was almost new, and I have not had that problem. But I have taken apart engines that had flat rollers in the starter clutch, and obvious signs of poor maintenance ......just haven't experienced it my selfpalepainter wrote:That may be true. But a little access wont hurt. The access bolt is flush with inside of case and there is no place for dirt to collect. The bolt is sealed with Teflon washer and wont allow oil out or anything in.CYBORG wrote:My take is that if the oil is not changed often enough, or the bike sits a long time without running, or the wrong oil is used, the starter clutch rollers stick. The hole being drilled allows you to clean/lube the rollers. I feel that drilling a hole into a closed oil area will create a place for dirt and water to enter the system. Use the right oil, change it often, and run the bike from time to time,....and a hole is not needed
- palepainter
- Zinc Member
Polished and painted linkage. Assembled right side today. Covers are just on for me to get a peek at progress. Waiting on T42015 wheels for tensioners.
purdy!
Beautiful engine. How did you do the silver stripe?
1977 Gl 1000
1976 F1 750 SS
1973 Ironhead chopper
2007 Road King
1974 dohc 450 chopper project
1976 Gl 1000 parts bike
600rr parts bike
1976 F1 750 SS
2007 Road King
600rr parts bike
- Patriccio
Low whistle.
- 683 Views
Last post by salukispeed
- 8 Replies
- 369 Views
Last post by rcmatt007
