GL1000 75 from France
Re: GL1000 75 from France
It is fairly common for the orings on the cross tubes from the elbow at the top of the heads to the thermostat to leak, especially after working on them. ( carb removal) They leak inconspicuously down the unseen side of the elbow and follow the head gasket around the head giving the appearance it is leaking from below. You can usually tell by wiping your finger on the underside of the coolant elbow where the tube meets it. If it’s wet , that’s likely your leak.
I can usually just roll the tube in my fingers and it will seal up again. They seem to leak after sitting a while and a cold spell. (Must shrink?)
- laurentg
Thanks for your advice ! I rechecked and elbow is dry, drops appears at the junction of the exhaust header and muffler, for the #3 cylinder pipe. This night, a puddle of coolant was created, about 3 inchs diameter . . .
I'll try to tighten the head bolts (I think I can do that without removing the camshaft ?!?) if it can be helpful . . .
GL1000 '75, CBX 1000 '78, CM 400 T '80, Triumph tiger 955 '02
Hapiness secret isn't to get all you desire, but to love what you have.
"Earth provides enough to satisfy every man's needs, but not every man's greed."― Mahatma Gandhi
If a gasket has blown, it is unlikely that torquing the bolts will do any good. Camshaft removal would not necessary.
With that much water in the exhaust, the machine must be steaming heavily out the pipes when running, no? That would confirm a blown gasket.
- laurentg
Yes, steam on the right exhaust (as the golds use to do I presume), but effectively more than usual when I ran the engine yesterday . . .
- laurentg
Hello,
Some news of the engine stand, not finished yet, my pupils works slowly . . .
looking good.
- laurentg
On his wheels !
- laurentg
In use !
- laurentg
I will publish the drawings of the stand after being corrected (brackets dimensions merely) !
- Buli
- laurentg
So I found the reason of the "tac tac tac" under acceleration : conrod bearing cyl #4
So I search blue bearing ref 13215-371-003 (with holes, for cyl 2-4).
These parts are discontinued at my honda dealer
Any adress where to order these bearings ?
Thanks in advance.
Thanks in advance.
- toolbox
There's a 13215-371-003 in Germany...
https://www.ebay.com/itm/Honda-Lagersch ... eP&vxp=mtr
And the other one in the U.S...
https://www.ebay.com/itm/Honda-13323-37 ... IX&vxp=mtr
It looks like they ship to the EU...
- laurentg
Thanks for the info, bearing orderer in germany !
- laurentg
I hope it will be OK, normaly this ref is drilled and the pict on ebay show a part without hole . . .
