GL1000 75 from France
- Zinc Member
Re: GL1000 75 from France
Salut Laurent, tu l'avais en France chez Bike Parts pour 20,90€.
Amicalement.
Jean
Amicalement.
Jean
3800 Vélosolex (2)
125 MBK Skyliner
Naked 80 1100 GL almost complete
80 GL 1100 project
2003 GL 1800
125 MBK Skyliner
80 GL 1100 project
2003 GL 1800
- laurentg
Ah, merci de l'info Jean, ça peut servir si les allemands sont pas bons . . .
GL1000 '75, CBX 1000 '78, CM 400 T '80, Triumph tiger 955 '02
Hapiness secret isn't to get all you desire, but to love what you have.
"Earth provides enough to satisfy every man's needs, but not every man's greed."― Mahatma Gandhi
- laurentg
I was offered bearing from gl1100/1200 (part 13215-463-003 instead of 13215-371-003 for the gl1000). I noticed the gl1100 have the same crankshaft diameter (43mm) but I'm not sure it's OK to use these bearing on a GL1000 . . . If someone experienced that, thnaks in advance for sharing !
- Zinc Member
Laurent, d'après les fiches de CMNSL pour une 1000 de 75, la référence est: 13321-371-003 et serait valable pour:
http://archwayintl.com/e-store/index.ph ... ts_id=8728
Elle n'est pas dispo chez Bike Parts et Cmsnl.
Pour ta question, je ne sais pas.Tu auras certainement une réponse.
Amicalement.
Jean
Amicalement.
Jean
3800 Vélosolex (2)
125 MBK Skyliner
80 GL 1100 project
2003 GL 1800
125 MBK Skyliner
80 GL 1100 project
2003 GL 1800
- laurentg
ref 13321 is for the main bearing, in my case, it's a conrod bearing that failed (and also weared the crankshaft . . . ). I manage to deal with it, can't afford a new crankshaft or a whole used engine . . .
En tout cas merci pour l'adresse de Bike-parts.fr !
- laurentg
And another surprise in the crankcase, the shield around the "damper" primary chain/clutch axis pinion was cut by a pin of the "damper" clutch pinion. . . Hopefully, I have a spare shield (but no damper pinion, I think I can re-use it ?!?)
- Zinc Member
Laurent,la référence 13215-371-003 est dispo chez CMSNL
https://www.cmsnl.com/honda-gl1000-gold ... kz3mN_iaM8
Jean
Jean
3800 Vélosolex (2)
125 MBK Skyliner
80 GL 1100 project
2003 GL 1800
125 MBK Skyliner
80 GL 1100 project
2003 GL 1800
- laurentg
Cool aussi CMSNL !
- laurentg
Modified drawings of the engine stand !
- laurentg
- laurentg
Ready for soda blasting and painting of the engine !
- JamesPal
Your engine stand is beautiful, great engineering job. I'm getting ready to split the case on my 1100. My plan is to do it on a work bench. It was unclear to me how you resolved the bearing problem. Did you use the 1100 bearing? Sorry, my French is bad.
'85 GL1200I
'81 GL1100 STD
'72 CB450
'85 GL1200I
'81 GL1100 STD
'72 CB450
- laurentg
Thanks for the compliment James.
No, I didn't used the 1100 bearing, il was a main bearing ref and my problem concerned a conrod bearing (and the related wear of the crankshaft journal).
- laurentg
- laurentg
wash primer :
One coat of polyurethane 2K white (to lighten a bit the final metalized coat)
The metalized coat, direct gloss :
