Sunrise - 1977 GL 1000
- Mark King
Re: Sunrise - 1977 GL 1000
I've tried plastic welding on these before. They fail as well for the same reason. Incompatibility. Plastic welding works when the plastics being welded are the same as the weld material. No kits I've seen match the plastic in these old covers.
This stuff stuck better than anything I've tried in the past. If it hadn't been cranked /levered like it was it may not have a been a perfect bond but it may have held. The original piece was holding well as well, until it was levered by the tab. I couldn't break it off with my hands.
I will try again with a thinner tab and a more gentle attitude.
M King
1977 GL1000 - Under s l o w restoration
1981 CB900C - Rebuilt but stripped spark plug thread
2002 VTX 1800 -Current Rider
1984 GL1200 Aspencade - Restored and Sold
1980 Suzuki GS850G - Restoration on hold
1985 750 Nighthawk SC - Sold
1976 GL1000 - Yellow - Restored and Sold (regret the sale)
1981 GL1100 - Naked - Restored and Sold
Unless I am mistaken the tab was missing to begin with. Hard to weld something on that is missing.OCR wrote:A plastic welding kit would give better results.
fortunately I still had a piece from a broken tab. I used abs cement and then cut a piece of fiberglass and reinforced the inside with the glass an a layer of abs cement
I just cut a piece of aluminum angle and use JBWeld to glue it to the cover. Several of them have held up very well.
that's how I did it on my 78. Been working fine for yearsrobin1731 wrote:I just cut a piece of aluminum angle and use JBWeld to glue it to the cover. Several of them have held up very well.
- OCR
With the kit you can fab up the part.
79 CX500custom
76LTD
77Goldwing
Secretary Caroline Lodge 681
76LTD
77Goldwing
- Rusty Probie
Hi Sunrise, if you can get somebody with a 3d printer to make that tab for you then try the Qbond.
Hope this gives you an idea.
I have a K100rt and the R/S fairing had a broken tab. I did not have the Qbond at the time just drilled a hole and screwed it on.
Good luck.
Good luck.
I think the problem with just attaching a tab is that there is so little surface to attach and the glue/adhesive/cement is never as good as OEM. that is why I used some glass/cement behind the tab
- Rusty Probie
Yes that would sure give it more support and make it stronger.rcmatt007 wrote:I think the problem with just attaching a tab is that there is so little surface to attach and the glue/adhesive/cement is never as good as OEM. that is why I used some glass/cement behind the tab
- Mark King
Thanks for the tips and hints.
Definitely going back at this soon.
Had a hernia operation two days after I broke the tab and got behind at work so after I catch up I am going to try this again.
Cheers
Cheers
M King
- Mark King
So back at it today. What is it they say about stupid - keep trying the same thing hoping for a different result ...
Anyway, built the panel back up. This time I used a dremel to cut back to fresh plastic and then used gorilla tape and popsicle sticks to hold the shape. It came out a little thin in the end but I will try to add a bit to it later. After it cures for another day I will try to put a bit of a tab on it - keeping it thin this time. Just enough to hold it in place. After all the spring and screw at the bottom should actually hold the panel. Stay tuned ...
Oh yeah and by the way - I still stand by the claim that this stuff can replace and fill in missing pieces on these old panels - as long as it gets a good grip on clean plastic.
M King
- Mark King
So it's certainly not the most beautiful job, and the popsicle stick, tape, toothpick, hot glue and paint stick mold I made slipped during the cure so it's not quite slanted the correct way, and it is smaller than the original, but it holds well enough and slips into place easily.
I might fill the gaps, I might not. So other than cleaning up a few remaining slops, I'm calling it done so time to get this ready for paint.
M King
- Mark King
Does anyone know how to test a fuel gauge that is out of the bike for a 77?
M King
Use an ohm meter to check for continuity between to two posts on the back. If you have any,...most likely the gauge is good.. Most problems are related to the sending unit in the tank. Or the 7v unit that reduces the voltage to the unitMark King wrote:Does anyone know how to test a fuel gauge that is out of the bike for a 77?
- 3 Replies
- 290 Views
Last post by ericheath
