1978 GL 1000 JUNK YARD DOG PROJECT
gdonlo04
Re: 1978 GL 1000 JUNK YARD DOG PROJECT
#61
Post by gdonlo04 »
the frame will come back from the painter soon, so i am ready to start gathering my carbs and engine. i have an engine GL1E-2024552. A 1978 FRAME AND 1978 FINAL DRIVE. carbs are ,..758A looks like it belongs to 1976+ 2 other sets to select from need to get those numbers. i am still reading if this will al go together. i need my final drive numbers. from what i can deduce the engine is a 76 and the carb is a 76. now need to check on the frame and final drive match
gdonlo04
#62
Post by gdonlo04 »
need paint but the pistons look new. .JPG[/attachment]
gdonlo04
#63
Post by gdonlo04 »
cleaned up the fork end and shifter.
gdonlo04
#64
Post by gdonlo04 »
gdonlo04
#65
Post by gdonlo04 »
my new tool worked great.
gdonlo04
#66
Post by gdonlo04 »
Pulled the bearing out of the rear wheel as well as removed the flange. The flange did not come off easy. had to use a gear puller to break it free. no grease on these, dry as a bone. The tool made from instructions on this site, to punch out the bearing, worked. Evaporust worked AWESOME, getting the rust off the flange. interesting thing. no O-ring on the flange as outlines in the Clymer book. looks like I will purchase a new O-ring and install . Bearings are shot, need new ones.
gdonlo04
#67
Post by gdonlo04 »
gdonlo04
#68
Post by gdonlo04 »
can anyone comment of the spider cracks inside the wheel hub?
#69
gdonlo04 wrote:can anyone comment of the spider cracks inside the wheel hub?
If you're talking about the aluminum center of the wheel itself, they may not be cracks, but rather casting marks. Lots of Honda castings look terrible on the unfinished surfaces. Just a thought...
gdonlo04
#70
Post by gdonlo04 »
thanks.
gdonlo04
#71
Post by gdonlo04 »
took wire wheel to the caliper then paint stripper for the hard to reach spots. even hit it with w brass wrie wheel. next stop a
little sanding and polisher. i think i will keep then unpainted for now. if I splurge looking for stainless brakelines to match.
gdonlo04
#72
Post by gdonlo04 »
Finally able to get the piston out. had to purchase new bleeder and attached my front break master cylinder with line to the rear break. stuck a piece of bicycle tire tube between the two halves to cut off the other side w/o the piston. came out beautifully. now i will spray with paint removed and repaint with caliper paint.
gdonlo04
#73
Post by gdonlo04 »
having difficulty locating the tool to remove front bearing retainer ring. purchased a tool with good rep per the site. notches did not line up and might have buggered up the notch on the wheel. now nee advice as to getting this ring off. any help out there? i have seen using a flat head screwdriver on care bearing rings. metal is pretty soft on the ring.
purchased a tool from harbor freight. it has round post and not square . no luck with it yet.
#74
I made a tool for removing the retainer from an inexpensive socket. Takes some fiddling around, but it has worked well for me. Um, just a thought, did you know the retainer is 'staked?' There is (or should be) a dimple near the outside edge of the retainer made with a punch that deforms the threads and locks it into place. You should take a drill bit just a tad larger than the dimple and carefully drill it out before trying to remove the retainer.
gdonlo04
#75
Post by gdonlo04 »
i will look for the dimple. i drill the retainer side and not the wheel correct? then purchase a new retainer? i purchased a tool made from a socket it did not work , so i am back to square one. maybe make my own. thanks
