1977 barn find
Re: 1977 barn find
Looking good!
Re: 1977 barn find
Clever repair to the gas line. Heads look good.
Re: 1977 barn find
Here is the question. I have two 1100 motors in my back yard that I bought for parts. Will the cam from a 1100 fit into a 1000 head? I really don't want to pull the head back off.
OR does anyone have a right side cam from a 1000 they will part with.
PLEASE reply if you have any answers.
Thanks Dave
Re: 1977 barn find
Need to find a 77 cam.
Will the 1100 cam fit? Yes. Will be the same as the 77 cam? No.
Re: 1977 barn find
Will it work?
Re: 1977 barn find
leggman wrote:Will it work?
NO
Re: 1977 barn find
I could replace both cams with the 1100 cams if that would help.
Re: 1977 barn find
could you say that a little louder?
Re: 1977 barn find
I think what Robin is saying is that each year of the gl1000's had different and specific cams, so even if it fit the 1100 cams are not set up for the 77 carbs
- OCR
Re: 1977 barn find
Go with an electronic tach!
79 CX500custom
76LTD
77Goldwing
Secretary Caroline Lodge 681
76LTD
77Goldwing
Re: 1977 barn find
I am not using the stock carbs. I am using a single carb like I did on the 79
https://www.youtube.com/watch?v=p1no3ogWds4
Re: 1977 barn find
Re: 1977 barn find
I know you guys are rolling your eyes and saying" when is he going to realize that 1100 cams won't work on a 1000 because of the points ignition" Well after going out in the heat and taking the heads off the worst of my 1100 parts bikes It dawned on me.
I guess the plan is to not have a tach until I can come up with a good used cam. Or like a much wiser person said
I have come too far now to let a stupid mistake stop me.
Re: 1977 barn find
I did put up one on ebay
Re: 1977 barn find
As suggested by OCR you could go with the cam as several members here have done. They have lopped off tach part and made a cover for it. Tach will need to be electronic, one from many 80-90 year Honda four cylinders will work. You’d also need an electric fuel pump like your other build, especially since the carb bowl is undoubtably higher than stock.
You can also put both 1100 cams in but you’d need a different ignition source. No easy work around to that one.
- 9 Replies
- 319 Views
Last post by chewy999
- 21 Replies
- 805 Views
Last post by Easter
- 19 Replies
- 2335 Views
Last post by rockyhayes
- 10 Replies
- 377 Views
Last post by Rockdog
