76 LTD Restoration
Re: 76 LTD Restoration
I'm pretty sure we haven't seen such fine examples of LTD's around here in a while. This thread turned into a 2-fer! Interestingly, JetDr's was a restoration and John's is an original. And both in Metro Phoenix!
Looking forward to seeing (and participating) in JohnnyNumbers' refurb.
Oh yeah, he's alive and well. I just finally wore him down!Easter wrote:Is your cousin still alive? Hard to imagine he would willingly let that bike go. Lucky you.
John
1976 Honda GL1000 LTD
1999 Honda Valkyrie Tourer
2001 Kawasaki ZRX 1200R
desertrefugee wrote:I'm pretty sure we haven't seen such fine examples of LTD's around here in a while. This thread turned into a 2-fer! Interestingly, JetDr's was a restoration and John's is an original. And both in Metro Phoenix!
I'm counting on it!
John
- dbtroudy
Welcome to the LTD owners club. Just curious to find out what your serial number is. My LTD is #859 in the sequence.
Don
Don
DBTroudy
Fullerton, CA
'03 GW GL1800 Yellow
'76 GW GL1000 LTD #859
'75 CB200T
Fullerton, CA
'75 CB200T
I'm assuming the number stamped on the steering head is the serial number. If that's correct then the last three numbers are 871.dbtroudy wrote:Welcome to the LTD owners club. Just curious to find out what your serial number is. My LTD is #859 in the sequence.
Don
I'm attaching a picture of the start of the refresh. I polished the valve covers and replaced the gaskets. I removed the front brake calipers and the front master cylinder today. If I get a chance tomorrow I'll remove the rear brake caliper and master cylinder. Not much to look at but at least it's a start.
John
- Front Brakes.JPG (129.57 KiB) Viewed 334 times
John
I've decided to send the rotors to Hampster to have them drilled (sorry desertrefugee). According to the Honda shop manual there's supposed to be a O ring between the right rotor and the hub and it shows it in the diagram. Of course when I took off the right rotor it wasn't there. I figured no problem, I'll just order another one from someone. I checked with Western Honda, Consolidated Motor Spares and Honda Parts house and their diagrams even don't show an O ring (my shop manual does). So how critical is this O Ring? Can I just find one that's the proper diameter and use it?
The good new is that I found multiple sources for the speedo cable I need to replace!
John
John
John
- flyin900
John, I did a full nut and bolt restoration on a 1976 GL1000 and there was no O ring that I recall on any of the front brake rotors on either side. I do see the part noted in the Honda shop manual and a best guess is it would be inside the hub near the right bearing and not on the outside by the rotor. The fiche only shows the packing item #10 on that side and that is a metal spacer that sits inside the speedo drive gear housing behind the drive gear.
Current Bikes:
Thanks for the info Flyin. I'm not going to worry about the O-Ring, it's time to move forward.flyin900 wrote:John, I did a full nut and bolt restoration on a 1976 GL1000 and there was no O ring that I recall on any of the front brake rotors on either side. I do see the part noted in the Honda shop manual and a best guess is it would be inside the hub near the right bearing and not on the outside by the rotor. The fiche only shows the packing item #10 on that side and that is a metal spacer that sits inside the speedo drive gear housing behind the drive gear.
John
I will have to look when I get homedbtroudy wrote:Welcome to the LTD owners club. Just curious to find out what your serial number is. My LTD is #859 in the sequence.
Don
This Saturday Desert Refugee and I are going to replace the timing belts and remove the carbs. Since I wanted to replace the radiator hoses I removed the radiator to make it a little easier. I removed the timing belt covers tonight and it looks pretty good under the covers. If I hadn't heard it so many times on this forum about replacing the belts, I might tempted to leave the belts alone but I know better than that.
I do have a question though. I'm rebuilding the rear brake caliper and I was able to pop out the brake piston that is on the large section of the rear brake. Unfortunately I'm not having much luck with the smaller piece. There is a brake fluid passage that letting the air escape, so I can't get any pressure behind the piston. I thought about reassembling the caliper but I figure the piston that's already popped out would pop out and block the other one. Any suggestions for the mechanically challenged would be greatly appreciated!
- Timing Belts.JPG (88.26 KiB) Viewed 243 times
John
if the seal is still there, place a small piece of wood and clamp it to the seal to close off the leak
Thanks for the suggestion. The wood didn't seal well enough but a couple pair of nitrile gloves did the trick. Thanks again!
John
- dbtroudy
When you change out your timing belts and replace them, make sure you follow Octane's shop talk guide for setting up the belts. page/ST Being off just one tooth on the belt will play havoc with your valves.
Don
Don
DBTroudy
Fullerton, CA
'75 CB200T
Fullerton, CA
'75 CB200T
Will do. I've reviewed it a few times and Desertrefugee has changed his timing belts a couple of times as well.
John
Ok, here's the deal:
I'm gonna go on record here as saying you could search the globe and not find a finer and more pristine, original LTD. This motorcycle is flawless. A survivor of the highest order. I felt privileged to lay hands on the machine today. In fact, I barely even got my hands dirty. THAT'S how nice it is.
Congrats for landing such a fine example, John.
