Jim Palmer's GL1100 Standard
- JamesPal
Hi, I'm starting to get back to work on my 1100. I bought this bike from the Honda dealer in Lynnwood, Washington back in 1982. the bike had about 3,000 miles on it then. Before the turn of the century it got another 50K of enjoyment. Life changed about that time and it got put away while 10 years passed. Then in 2010 it was time to bring the old girl back to life. On June 9, 2010 she was given the first bath in many years. The engine wouldn't start and it was pretty stiff to turn over. It was pretty clear it would need a through going over to be road worthy. This is what it looked like on that day back in June:
After a few months of work, it had new tires, wheel bearings, steering stem bearings, the swing arm had been removed and bearings greased, the frame carefully cleaned up and all of the rust remove and painted with Ace Hardware Oil Based Enamel (good stuff). The engine overhaul was started and I decided my skills were a little lacking. I thought the best thing would be to get a simpler bike to restore. The 1100 looked like this at that time:
The simpler bike was a CB450 and it came out like this:
Then A nice 1985 GL1200I showed on Craigslist for $500, it had been off the road for 10 years with a bad starter motor. It had to join the stable:
Here is an introduction of me and the project. The brake system overhaul was started on Jan 13, 2019 (Saturday). The last third of the video shows getting started on the brakes. I hope you will share your experiences, as I am sure to learn from this forum.
'85 GL1200I
'81 GL1100 STD
'72 CB450
'85 GL1200I
'81 GL1100 STD
'72 CB450
- JamesPal
Re: Jim Palmer's GL1100 Standard
The rear brake master cylinder reservoir hose is toast (literally). It appears the factory hose are no longer available from Auntie Honda. I have read PVC hose will stand up to brake fluid. Does anyone have experience with a good substitute?
'85 GL1200I
'81 GL1100 STD
'72 CB450
'85 GL1200I
'81 GL1100 STD
'72 CB450
Fuel line works.
Ditto what Robin said
- hatchward
Regular fuel line will degrade over time.The proper brake reservoir line is made from EPDM.It's available from summit racing pretty cheap.(https://www.summitracing.com/int/parts/ ... 2/overview)
1982 GL1100 Std - Daily Driver
1982 GS750SZ Katana - Mostly Unmolested
1998 Valkyrie - Latest Aquisition
1984 GL1200 Aspencade - Undecided Project
- OCR
JDA also makes brake lines for motorcycles.
JDA.com
JDA.com
79 CX500custom
76LTD
77Goldwing
Secretary Caroline Lodge 681
76LTD
77Goldwing
- JamesPal
Thanks, I will check them out.OCR wrote:JDA also makes brake lines for motorcycles.
JDA.com
'85 GL1200I
'81 GL1100 STD
'72 CB450
'85 GL1200I
'81 GL1100 STD
'72 CB450
- JamesPal
Here is a short video from last weekend's activities. There wasn't much time to work on it, but you need to do something every week. In this video the front and rear master cylinders were disassembled. I got a couple pans of parts rolling around. The castings need to be stripped and painted. Parts are on the way.
'85 GL1200I
'81 GL1100 STD
'72 CB450
'85 GL1200I
'81 GL1100 STD
'72 CB450
- flyin900
Jim, Looking good so far. Keep up the tutorials.
I recommend the DupliColor engine or caliper enamels to repaint the brake masters and then follow the instructions on curing it at temperature to help it to resist the brake fluid. I usually use my BBQ set to the appropriate temp, as it is outdoors and the smell of the curing paint is not an issue. The oven works too, yet you will get some curing paint fumes in the house which may or may not be an issue.
Duplicolor has everything from gloss black to semi gloss colour wise which are a close match to the original Honda finishes.
Current Bikes:
- chewy999
flyin900 wrote:Jim, Looking good so far. Keep up the tutorials.
That means whether or not SWMBO is in the house!!!!!!
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
Current bikes
- JamesPal
Very good advice, my SWMBO has a very sensitive nose, I would never get away with it I will use plain caliper paint. It works fine and if it gets a little brake fluid it can be easily touched up.chewy999 wrote:flyin900 wrote:Jim, Looking good so far. Keep up the tutorials.
'85 GL1200I
'81 GL1100 STD
'72 CB450
'85 GL1200I
'81 GL1100 STD
'72 CB450
- CrazyJerry
That GL1200 in the photos above is just about a dead-ringer for the one I have!
Good luck with the 1100 - nice bike!
~CrazyJerry~
~CrazyJerry~
- JamesPal
THX CJ- I had great luck with the 1100 this last weekend. Check out the next post.CrazyJerry wrote:That GL1200 in the photos above is just about a dead-ringer for the one I have!
~CrazyJerry~
'85 GL1200I
'81 GL1100 STD
'72 CB450
'85 GL1200I
'81 GL1100 STD
'72 CB450
- JamesPal
I got to meet Pony Ruiz (AKA Bob) on Saturday. He had some important parts that he wanted to sell. Namely a GL1100 engine. The serial number is 2122747 which I believe makes it a '81 and that is a match for my 1100. The engine that was in my bike is S/N 2102047 and I believe it is an early '81, about the 2047th engine. When I bought the bike in 1982 I believe it was the dealer demonstrator. I bought it in summer of 1982. The Pony Ruiz engine was made 20,700 engines later. Not exactly assembly line twins, but close enough. Bob also sold me a 1983 gauge set. Happy to get rid of the 85 MPH speedo. Here is a short video showing the MAJOR score! This should get this project going. Pony Ruiz is a great guy- THANKS!
'85 GL1200I
'81 GL1100 STD
'72 CB450
'85 GL1200I
'81 GL1100 STD
'72 CB450
- CrazyJerry
It's January - where's all the snow!
Good deal on the engine - looks like you could eat off it!
~CrazyJerry~
~CrazyJerry~
- 9 Replies
- 564 Views
Last post by rcmatt007
- 1 Replies
- 1369 Views
Last post by essjayarr
- 0 Replies
- 346 Views
Last post by toomanybikes
- 6 Replies
- 1600 Views
Last post by Jimtt
