2019 Spring Project: 'Layla'
Liam
Re: 2019 Spring Project: 'Layla'
#151
Post by Liam »
You win the prize for the shiiiiniest bits. lolol lolol
They look fantastic.
#152
It's been a one step forward, two steps back kind of day. Buttoned up the exhaust, rear air lines, fuel lines, air box, and assorted hoses, then took a break for lunch. Picked up a few gallons of fresh fuel on the way back to the storage unit, downloaded that into the tank, checked over a few things, and hit the start button.
She lives! lolol lolol lolol
Then came the fuel leak...
So now the carbs are off and on the workbench at home. From what I could see while they were still on the bike, the leak seems to originate between the #3 carb and the plenum. Plenum floor was dry, as was the venturi. That's what I get for NOT testing them ahead of time. shakehands shakehands shakehands
#153
I did a 'hanging' fuel supply test to pinpoint the leak. #3 carb was missing the d- ring between the carb and plenum. No clue how I missed it, or where it is. Good thing is that I keep a bag of old parts just in case. Not the ideal solution, but it works. If I would have done a simple vacuum test when I rebuilt them I would have found it right away.
She's gaining some weight! I just had to toss the seat on and ride her around the storage lot, lol! Still need to do some fine tuning; tried to adjust the clutch, but didn't do very well. Should have done it when the rear wheel was still off...
ritalz
#154
Post by ritalz »
Are you going to pull the clutch cover? Other than that, why would it have been better while the wheel was off? Please explain.
#155
The 80-81 has a screw and lock nut plunger rod that is accessible by just removing a cap (same as the stator) in the center of the clutch cover. 82-83 engines are non- adjustable other than at the cable ends. It's just harder to get a screwdriver and a 10mm wrench in there and see what you're doing, all at once.
The procedure is simple. Fully slacken clutch cable, both at hand lever and engine. Remove cap, and loosen lock nut. Screw IN plunger rod until slight resistance is felt. Back out plunger rod 3/4 turn. Tighten lock nut. Install cap. Adjust cable at engine for about 5/8 inch play at hand lever. Adjust cable at hand lever for 1/4 to 3/8 inch play. Go for a ride!
ritalz
#156
Post by ritalz »
That procedure sounds a lot like the 1000 clutch. Can't say I even noticed the cap being on the motor I just dropped in the frame. I'll have to look.
#157
ritalz wrote:That procedure sounds a lot like the 1000 clutch. Can't say I even noticed the cap being on the motor I just dropped in the frame. I'll have to look.
It is just like the 1000 except the cable and arm are on the outside, and it's just a small cap to access the plunger rod.
CrazyJerry
#158
Post by CrazyJerry »
What Track T 2411 said above!
Bike is looking good - nice work!
~CrazyJerry~
#159
CrazyJerry wrote: Bike is looking good - nice work!
~CrazyJerry~
Thanks, man!
#160
Layla is home! Rather than load up and haul the rest of the plastics and sundry parts, I took the back way and rode her 'as is' the seven miles home.
Time to get her dressed!
Rednaxs60
#161
Post by Rednaxs60 »
Looking good! I bet it was nice to feel the wind in your face.
Ernest
1985 GL1200 Limited Edition
2014 Can-Am Spyder RT LE
2021 Royal Enfield Himalayan
2008 GL1800 (sold)
#162
A very active storm cell is bearing down on us as I type this. I raced to get as much installed on the bike as possible before riding her back into town and tucking her away in the storage unit. All I have left to install is the rear rack, backrest, and saddle bag brackets, and the front fairing lowers.
She's running great, even without any carb adjustments or dynamic sync. I still need to adjust the clutch, re-bleed and adjust the rear brake, and play around with a few 'fit and finish' issues.
I'm hoping to take our first real ride on Saturday.
#163
A few pics from yesterday...
Freshly polished rocker cover compared to the original...
Shiny!
I wish I could leave her nekkid!
ritalz
#164
Post by ritalz »
My project won't look near as nice when done. But then again, I won't be keeping mine.
Liam
#165
Post by Liam »
You are doing beautiful work.
