2019 Spring Project: 'Layla'
- Jonesz
Re: 2019 Spring Project: 'Layla'
Hey TrackT 2411 you have a great looking cluster of shiny things. Looking good to a guy who is attracted to things like that. Good job so far!
Jonesz
1979 Suzuki GS850. Sold
Thanks... I can get obsessed sometimes, so I have to tell myself when to call it done!Jonesz wrote:Hey TrackT 2411 you have a great looking cluster of shiny things. Looking good to a guy who is attracted to things like that. Good job so far!
Tomorrow's weather should be nice, so it's final carb cleaning day. I'll have to squeeze in mowing the lawn and possibly taking a good ride, because Monday's weather looks pretty crappy.
I splurged and ordered all the brake kits and a few other parts. Nearly $500.00 in two days. I don't know if I'm happy or sad!
I can hear those carbs calling me this morning, lol! Problem is, so is the open road!
I guess it's carb time, as there's suddenly some hunnydo's on the slate for the day. I might get to slip in a few miles later...
Forgot to mention I had a heck of a time getting the glued - on limiting caps off the idle needles. I finally got out the old Weller soldering gun and heated the cap, then pulled it off with a pliers. As is typical for my projects, the last one was especially stubborn...
My parts orders are rolling in; I have everything to do the brake system except lines. I am a bit unhappy with Partzilla.com, though. It seems one item is 'delayed,' and they took three days to notify me. The problem is, they don't ship any of the order unless you specifically contact them and request it, which delays their already slow shipping even further... GRRRR!
Into two...
Into one! I didn't even have any parts left over!
The floats are set and a bench sync done. I'll do a slide check with the shop vac and probably bench check for leaks right before installation, which will hopefully happen in a couple of weeks. Next up is the brakes!
That does it. My next set is coming up to you for refurb. Very nice!
Thank you. That means a lot! I'd be happy to do others' carbs, but to be competitive with the true experts here on the forum, I'd be making about 3 cents an hour, lol! (Yes, I'm VERY slow...)desertrefugee wrote:That does it. My next set is coming up to you for refurb. Very nice!
- CrazyJerry
You've got some time in those carbs but they lookin' really good!
~CrazyJerry~
~CrazyJerry~
Thanks! I just hope they work as good as they look!CrazyJerry wrote:You've got some time in those carbs but they lookin' really good!
~CrazyJerry~
Received my Partzilla order today! Whoop whoop! I'm still waiting for two fork bushings (which Partzilla didn't have), but I have more than enough stuff to keep me busy for a few weeks. Now if I could just get some non-50 hour workweeks...
Nice work on the carbs, a real clean bike.
Well, I'm committed now (or maybe should be, lol). Started stripping the paint from the brake components. They didn't really need to be painted, but I know they'd bug me later if I didn't do them up. I'm certain I won't get them painted today, and the forecast doesn't look conductive to painting tomorrow, but they'll be ready to go, at least.
- Liam
I have to say those carbs look absolutely fantastic. I am looking forward to seeing how the master cylinders turn out. 1100 rears are a swine, the castings were made from chocolate and fell apart from corrosion. An oddball cylinder too only used on the GL1100.
Keep up the great work.
Thanks for the encouragement, Liam. The bike has had just enough exercise and attention to keep everything working, sort of. The rubber boot seals on the calipers and rear master cylinder just seem to hold in the moisture and after so long everything becomes corroded. I plan on switching to DOT 5 brake fluid, which should help.
