Found a '79 to restore as my next project - "Freedom"
pidjones
Post by pidjones »
As the subject sez. Thought I had one lined up last week, but it sold the day before I was to go pick it up. I'm watching Craigslist and Facebook Marketplace. One in Minnesota is just too far to consider right now. Really want a '79 - they are just not that abundant.
I bought a parts bike a few weeks ago, but the engine is full of water and rust, only ~35% of the carb parts reclaimable (all pulled, disassembled, cleaned and boxed/bagged up). The stator measures good, and parts are coming off of the block pretty easily, but the cams are rusty so I doubt any bearing surface is useful. I plan to continue stripping the engine down to learn (never had one down all of the way) and see if there is anything else usable inside.
When (not if) I find the project bike, I'll continue the build thread here. I do have some parts saved from other projects and such - side covers, mufflers, and I think the forks and front wheel from the parts bike are rebuild-able.
pidjones
Re: Looking for a '79 to restore as my next project
Post by pidjones »
Third 'wing is aboard! Monday, I drove over 600 miles RT to pick up a '79 that seems to be in fairly good shape and fairly complete. Although the odometer shows <78 k miles, the 2017 registration only shows a little over 41 k. Tires less than two years old (Dunlops), it is largely rust-free. AGM battery. Wouldn't start, but it's about out of gas - I'm not realky worried about that, I'll get it running right. Compression checks good.
It had been "turned into a cafe racer" by removing the handlebars and replacing them with a couple straight pieces of 7/8" tubing. Seat replaced with a chunk of carved foam rubber. Tail light replaced with a plastic unit zip-tied on. No mufflers but clean shiny headers. It came with a complete set of Vetters including the key to the bags and covers. Stock headlight and ears are in place, but I'll need to cleanly remove the Vetter connector from the harness. Trying to find a local that wants them. It also came with the original handlebars and taillight mounting bracket including rear signals.
Needs: seat, grab bar, taillight, tool tray, front signals, front brake reservoir, clutch lever(broken). I have a pretty good muffler set and hangers for it from a previous build. It also needs a good refurb by tearing it down, polish and paint, rebuild. Also the left side cover is pretty trashed and poorly glued back together. I have a spare for each side however. I will no doubt find a ton of special fasteners (like the shelter hinge pins) missing. Planning to take my time on it, and get it really right. Looks like haunting ebay is once again a thing for me. Not my first show, new belts are on order as well as filter, carbs o-rings. I have (just in case) things like head gaskets on hand.
Congrats! Now get out there and take a few pics, lol!
Jonesz
Post by Jonesz »
Need pics for sure. Sometimes I think that the fun part of a restore is searching and finding the right part at a decent price. The hunt is part of the thrill. Looking forward to seeing your bike.
Jonesz
1979 Suzuki GS850. Sold
pidjones
Post by pidjones »
Pics will come, but probably in a week or so. Only room for two bikes in the garage, and right now the Hunley and 1800 (Black Pearl) have it (along with remaining parts of the parts '79 that I'm still disassembling). The new '79 is on the other side of the basement (supposed to be family room, but mainly junk now). Parked between the Uni-go trailer and a mountain of "stuff" that I'm not permitted to throw out. I'll have to back it outside, but it's a tight squeeze. Even more so now that I've remounted the correct bars. Three shows coming over the next two weeks, then I'll get time to work on it. I've already discovered quite a few screws stripped by not using JIS screwdrivers. I'll have to drill heads off, disassemble, vice grip the studs out, and reassemble with new JIS screws. Luckily my local Ace hardware carries them.
pidjones
Post by pidjones »
Spent the morning splitting the cases of the "parts" bike. Actually beating, crowbarring, sledgehammering, and using select language. Any engine that you have to do that to is a useless lump, but it was instructive for me as I had never split cases before. Would have been pretty easy save for the rusted ring-to-cylinder gap on #4 piston.
rusty 79.jpg (115.58 KiB) Viewed 446 times
Meanwhile, the target will remain in the other side of the basement nestled in "stuff" until I get time to move it into the garage. Three shows in the next two weeks for the Hunley, so I'll be busy with that.
bigscheaf
Post by bigscheaf »
pidjones wrote:Spent the morning splitting the cases of the "parts" bike. Actually beating, crowbarring, sledgehammering, and using select language. Any engine that you have to do that to is a useless lump, but it was instructive for me as I had never split cases before. Would have been pretty easy save for the rusted ring-to-cylinder gap on #4 piston.
Coercive and threatening language, when used correctly, increases chances of success by 50%, although I do have a 16 lb sledge when all else fails.
The '79 looks like a pretty nice sample to start work off of. Going to need to do much with the paint or is it pretty much good to go?
1983 GL1100 viewtopic.php?f=16&t=67673#
1981 CB900F (Resto-mod Project)
1979 CB750F (Wiseco 823)
pidjones
Post by pidjones »
Over-all not too bad, but there are some chips that might force an entire repaint. Left side cover is badly broken, but I have a spare. Just haven't checked to make sure it is black. Tail light on order. Watching for better prices on front signals. Might just swap the tool tray from my '78 back and forth until I find one cheap. Not in a hurry, though. This project is back-burner until after Barber Vintage Fest.
bigscheaf
Post by bigscheaf »
pidjones wrote:Over-all not too bad, but there are some chips that might force an entire repaint. Left side cover is badly broken, but I have a spare. Just haven't checked to make sure it is black. Tail light on order. Watching for better prices on front signals. Might just swap the tool tray from my '78 back and forth until I find one cheap. Not in a hurry, though. This project is back-burner until after Barber Vintage Fest.
Sounds about how the my 1100 is overall. Got a used "tank" on eBay that has great paint overall, but a few chips that would require a full repaint. At least you can take it out once you get it pieced back together and not worry too much.
And I know how it goes with throwing a project on the back burner. Well, technically two on the back burner at the moment.
pidjones
Post by pidjones »
A nice surprise today. Decided to do some looking around on this new '79 and found a wire leading from one of the fuses to.... a Dyna 3 module! It will come out and be replaced with stock points for my true restore, but might go in the Hunley if my planned Ford TFI module experiment fails.
Also, I've bought a taillight and located a seat (needs a new cover, but otherwise looks OK). Just need the unobtainium passenger grab bar and front HONDA emblem that goes over the brake spliter (I have the rest, just need the emblem). Of course, that is until I get into the brakes and engine/drivetrain details.
The left side cover was busted in four pieces (I have another) so I glued it back together with ABS plumbing cement. Still a couple small chunks missing, but it mounts Ok and with those chunks patched and some filling/sanding, it should do well for a spare.
I still need to get into the headlight housing and remove the spiced-in Vetter connection. Hope it isn't a hack job.
nasty rust on the transmission gears as well
pidjones
Post by pidjones »
rcmatt007 wrote:nasty rust on the transmission gears as well
That trany and case is history - I gave it to a friend that gets a little cash from recycle. The valves from the left head are getting ready to go to Joe Drum.
RIP: cookie
There's a name from our past ....
Gord anim-cheers1
pidjones
Post by pidjones »
Today, Judy and I drove to Covington, GA and picked up a seat for the '79 GL1000 (I found it on Marketplace). Judy also found a side table for my bed to replace the one that I busted with my head a couple years ago. Both need restored, and I'll order a cover for the seat tonight.
new seat.jpg (58.51 KiB) Viewed 347 times
busted with your head? ouch!
