1st time owner '80 GL1100 update
- Tin Member
- My Album: 80 GL1100i
Re: 1st time owner '80 GL1100, revised update
I have an update regarding my 80 Gl1100.
I bought a Randakks Carb overhaul kit with instruction manual. Very good pictures, it helped a lot.
I removed the Carbs and cleaned them thoroughly. Cleaned the jets and the fuel bowls. Replaced all the gaskets. Re-installed the carbs. Also replaced the Timing belts, spark plugs, fuel lines and filter, Cleaned the tank.
I bought the snyc gauges, After installing the carbs and hooking everything back up. I purged the fuel pump, and the bike started yippiy. But it won't idle. I had to screw in the curb idle screw in a lot. I checked compression, all about 90 psi. I have spark on both sides, all four plugs. But after starting it up, the mufflers on #2 and #4 side were basically cold compared to the other side were very hot.
I ran the motor today to about 3000 rpms, let go of the throttle and it slowly backed off and died. I checked the choke, seems to be working ok. But when I ran it up higher, it started to backfire.
I did replace the timing belts and made sure it was on the mark. I cranked it over and rechecked and it was dead on. But the one thing I didn't do was check the valve clearance.
When I put the sync gauges on, the vacuum was about 2-3. Most of the other bikes on the forums seem to be around 15-20.
Any ideas?
And another problem I found, the Neutral Safety switch is not lighting up. I checked that the bulb is working. It will start by pulling the clutch.
Any ideas?
There are three kinds of people, those that do math and those that don't.
Well, the compression numbers are pretty low. That said, seeing as the bike has been sitting for some time, I wouldn't worry too much about that yet. Things I would check would be the clamps on the intake runners (they can be a PITA to get tight), make sure every carb is getting fuel by loosening the float bowl drain screw (some people compare amounts between the carbs). Being an '80, the carbs would have the pressed in idle jets. Did you remove those for cleaning, as well? Here's a link concerning that procedure... viewtopic.php?f=54&t=67428
it is also easy to pinch an O-ring when attaching the manifolds.... so I have heard, never, ever happened to me
As counseled:
1) Slow speed jets.
2) Vacuum leaks
1) Slow speed jets.
2) Vacuum leaks
- Tin Member
I wish I came here first for the rebuild of the carbs. I spent about a month on the internet researching the procedures, watching youtubes, reading manuals etc. before I even started. Taking the carbs off will go faster this time around, since I've done it once before. I bought the Randakks carb kit and booklet when I did it the first time. But it didn't come with new idle jets, so no, they didn't get replaced.
Would it be beneficial to replace the PITA clamps with regular hose clamps?
When I first found this bike, I thought it was going to be an easy project. If I had known that the 80's Gold Wing was the one series that had a lot of problems, I would of looked elsewhere. For couple of hundred more $$$, I could of got a newer and road ready wing.
I would not use regular hose clamps. Once the bike warms up and cools down. retighten the clamps
- chewy999
It is possible to take the jets out to clean. I screwed a long thin screw into the jet, and then gripped the screw with pliers and a large file handle as a fulcrum. Despite the carbs being professionally cleaned, some of the holes were still blocked. Cleared them with a guitar string and carb cleaner.
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
Current bikes
... and you should not need new jets. The old ones can be cleared.
EDIT: Doh! I didn't see that Chewy is already giving you exactly that advice and provided much more detail.
- Tin Member
rcmatt007 wrote:I would not use regular hose clamps. Once the bike warms up and cools down. retighten the clamps
I warmed up the bike, then tried to tighten the clamps. I was surprised on how loose they were. I know I tightened them when I put them on.
- Tin Member
The Randakks Carb kit with the book, says not to replace or remove those jets. I'm going to take the carb off the bike and break it down again. I will let everyone know how it goes.chewy999 wrote:It is possible to take the jets out to clean. I screwed a long thin screw into the jet, and then gripped the screw with pliers and a large file handle as a fulcrum. Despite the carbs being professionally cleaned, some of the holes were still blocked. Cleared them with a guitar string and carb cleaner.
When you insert the screw, does the threads mess up the inside of the jet? How do you fix that?
Thanks for all the help.
- Tin Member
I've been a small engine mechanic for several years. There is one thing I would like to pass on to everyone that works on bikes. I see some people say use a guitar string to clean the jet holes. Lawnmower jets are very small and in the shop I was in, we used... Papered Wire Ties.
The kind you twist tie a bag shut kind. Not the plastic kind. Burn the paper off one end. Vwaa la! Very cheap, easy to come by, most times free.
- chewy999
I think I used a long 6mm screw, but you just need one that fits the jet and attains a grip. There obviously is some 'damage' but it is only in the top part of the body of the jet and not near the actual holes you are trying to clean. I didn't see a need to fix the damage. There are videos on YouTube that shows how to do it.TerraKacher wrote:chewy999 wrote:It is possible to take the jets out to clean. I screwed a long thin screw into the jet, and then gripped the screw with pliers and a large file handle as a fulcrum. Despite the carbs being professionally cleaned, some of the holes were still blocked. Cleared them with a guitar string and carb cleaner.
I think strictly speaking you're not meant to take these jets out, but with hindsight, some of the holes in mine were still blocked even after a professional clean.
Previous Rides,
Current bikes
Current bikes
Nice tip. I'll have to store that one in the good ol' brain bucket.TerraKacher wrote:I've been a small engine mechanic for several years. There is one thing I would like to pass on to everyone that works on bikes. I see some people say use a guitar string to clean the jet holes. Lawnmower jets are very small and in the shop I was in, we used... Papered Wire Ties.
- calif wingnut
Quote: When I first found this bike, I thought it was going to be an easy project. If I had known that the 80's Gold Wing was the one series that had a lot of problems, I would of looked elsewhere. For couple of hundred more $$$, I could of got a newer and road ready wing.
The 1100 series had few problems to speak of. The 80 had a swing arm defect in which yours may still have or not ? PM me.
Your vacuum readings are fine.
- DSC01397.JPG (109.45 KiB) Viewed 269 times
- Tin Member
Re: 1st time owner '80 GL1100 update
Since June 21st,
I took the carbs off the bike and carefully tore it down. Placing each carb piece in a numbered cup. I found the article regarding cleaning the Slow Jets. Took a #10 screw and screwed it in a few threads, the jet popped out easily.. And this was after cleaning it the first time.
So this time I read on line that someone boiled their carbs. One person said his was really bad, so he boiled them in Pine Sol and water for three days, then boiled them in lemon juice. I didn't want to take 3 days, so I did boil the carbs individually with their jets. I used a commercial detergent for cleaning pot and pans. I also added Citric Acid. Essentially Citric Acid is the same as lemon Juice. Well I didn't have any citric Acid handy, but I did have a bottle of Descaling solution for my Keurig coffee maker. The main ingredient was Citric Acid. I added it to the detergent and boiled each carb for an hour. When they came out, I used pressured air. Boy were they clean this time. There wasn't any dirt, oil, grime. Super clean. I carefully reassembled the carbs one at a time. Taking particular attention to the gaskets. Put it all together and install back on the bike.
I replace the ignitors, there was a article that if the back side melts, you can fix them, I opted to get a pair from Amazon almost new pair.
Cranked it up last night and it purrrred, idled down and kept running.
BUT
smoke was billowing from the left side of the engine. Gas was now pouring out from the bottom of the carbs. I checked the drain screw, yes they were in and tight. I pulled #2 and #4 intake manifold off and rechecked both screws and gaskets. They looked fine. Retighted and re-installed the manifolds. Started it up..... Still leaking gas .
The carbs are sitting on my table in my shop.....Again. Deal with it on Friday.
BUT
