Waking Donna; a '75 GL1000
Re: Waking Donna; a '75 GL1000
#31
A few rags to protect paint and a pry bar on the front makes it easier after you drop the rear.
#32
Greased pigs are easier to handle.
Chainman
#33
Post by Chainman »
It's a girl!
Thanks for the tips.
In addition to your teachings, I found, after attempting to remove the rectifier (the finned electric device?) with no luck, that the battery housing could be removed with two bolts and then I had plenty of room to pull the tank.
Thanks again, you folks are great.
1975 GL1000
Chris in TN
#34
Post by Chris in TN »
Chainman wrote:
rcmatt007 wrote:on removing the tank.... the petcock must be removed.... then just imagine birthing a baby.... all the road gunk is the same as meconium
Great, when it's ready, I'll get my wife to push and of course, breathe. :-D
As a Lamaze coach/partner with a regrettable amount of experience in delivery rooms to my credit I snorted coffee through my nose when I read that. The wife came in to see why I was howling. Oddly, she didn't laugh... :lol:
Chris
Current fleet:
1976 GL1000, 1978 GS1000E, 1979 GS1000S, 1981 CM400C,
1986 RG500G, 1988 R100RS, 1991 K100RS, 1997 GSF1200
Chainman
#35
Post by Chainman »
I'm running out of things to remove. :-D
I'm going to need one of these pin spanners:
Will this work?:
https://www.amazon.com/Vmotor-Chrome-Va ... 256&sr=8-8
Thanks
1975 GL1000
pidjones
#36
Post by pidjones »
I think there should be one in the standard GL1000 tool kit.
Chainman
#37
Post by Chainman »
pidjones wrote:I think there should be one in the standard GL1000 tool kit.
Thanks, I have that.
1975 GL1000
pidjones
#38
Post by pidjones »
There should also be a "cheater" in there that slips over the handle to give more leverage.
Chainman
#39
Post by Chainman »
Happy New Year.
I managed to remove the frame from the engine and walk the engine up some planks onto a bench. Santa brought me a full set of gaskets including valve stem seals so that's where I'll start to put things back together.
When I removed the left side cam, I found this:
The rocker arms look fine.
How much of a problem is this?
1975 GL1000
#40
That doesn't look good... you might be ok as, depending on the design, there might be a 'transition' area of the cam lobe that actually doesn't touch the rocker pad. Can't say for certain though...
#41
No, that cam looks to be junk. I would be real suspicious of the rocker arm pad too.
Chainman
#42
Post by Chainman »
Does the camshaft from a 1979 fit the 1975? I see some on ebay.
1975 GL1000
#43
It will "fit" but there are differences. I think the 75-77 cams are the same. But do some checking. I believe ericheath has some info on that.
Chainman
#44
Post by Chainman »
Thanks
1975 GL1000
#45
Fit but different profiles. You want a 75-77. They’re getting harder to come by as more people are putting them in 78-83 bikes for perceived performance gains. The breakers have gotten to think they’re gold. Be patient and you’ll find one cheap. Sometimes you’re better off looking at buying a complete head, then you have some spare parts to clutter up the garage. lol
Heads can be swapped side-to-side, but cam cannot, so you need a left cam.
