Waking Donna; a '75 GL1000
Re: Waking Donna; a '75 GL1000
remember with allen head machine screws you can get a lot of torque and strip out the threads
rcmatt007 wrote:remember with allen head machine screws you can get a lot of torque and strip out the threads
That's why they make torque wrenches. And also one reason the bolt kit comes with instructions and advice.
and next you will suggest anti-seize.... what does valproic acid have to do with it?
- mopehead440
And I assume that you strip the JIS screws......using a Phillips Head screwdriver??????
1975 GL1000 Red
1975 GL1000 Blue/Green
1976 GL1000 LTD
1976 GL1000 Sulphur Yellow
1997 Valkyrie Custom
1999 Valkyrie Interstate Trike
2001 Valkyrie IS
2012 GL1800
2014 Indian Vintage Chief
2015 Indian Scout
2016 Indian Jack Daniels Limited Springfield
1976 GL1000 LTD
2001 Valkyrie IS
2012 GL1800
2015 Indian Scout
only after they dance around a pole..... opps… non PC
- Chainman
I had to look that one up.rcmatt007 wrote:and next you will suggest anti-seize.... what does valproic acid have to do with it?
- Chainman
Finally had a chance to paint the engine today. Glad I did; made a huge improvement. I tried my hand at shining up a belt cover with some 600/800 wet sand by hand. I'm still not set up for polishing. Here's some pics:
- IMG_20200328_211551.jpg (113.36 KiB) Viewed 255 times
- IMG_20200328_211617.jpg (126.26 KiB) Viewed 255 times
- IMG_20200328_213323.jpg (122.23 KiB) Viewed 255 times
I just use my drill press in its highest speed with some Harbor Freight wheels. Felt seems to go the fastest, but really stinks if you overheat it.
- mopehead440
Lotta buffing time....belt covers down, valve covers next!
- 1D1F8507-1172-49A5-AE76-164045F5B7A8.jpeg (213.17 KiB) Viewed 235 times
- FFD139FB-7699-46FE-8E4F-7E86847567B8.jpeg (207.59 KiB) Viewed 235 times
1975 GL1000 Red
1976 GL1000 LTD
2001 Valkyrie IS
2012 GL1800
2015 Indian Scout
1976 GL1000 LTD
2001 Valkyrie IS
2012 GL1800
2015 Indian Scout
- Chainman
Thanks for the tip. I've decided to only wet sand the covers for now. I'll come back to polishing after I know she runs.pidjones wrote:I just use my drill press in its highest speed with some Harbor Freight wheels. Felt seems to go the fastest, but really stinks if you overheat it.
Those look spectacular!mopehead440 wrote:Lotta buffing time....belt covers down, valve covers next!
- Chainman
Watch me pull a rabbit out of my hat:
Oops. Don't know my own strength.
I have one just like itChainman wrote:Watch me pull a rabbit out of my hat:
- Chainman
I managed to install a "new" clutch lifter plate without breaking it this time. The manual says tighten in "small increments". I must have been turning 1\128ths at the end there. I sure didn't want to snap another plate. What a relief it was to get them all torqued.
I do have a question about the location of the oil tube clip. I've searched my photos and can't get a good look at it and the parts fiche ain't much help to me.
Onto which bolt is the clip installed?
Some pics: Thanks for your help.
- Chainman
I think I have my answer. Found this online:
- photostudio_1586023337397.jpg (118.74 KiB) Viewed 156 times
- Chainman
Hello all.
Here's a photographical update: I still have to buy a water pump. Then the engine can get back into it's frame.
And to all who take the time to answer all my good questions and none of my bad ones, thanks.
- 10 Replies
- 904 Views
- 1202 Views
Last post by rcmatt007
