While I'm waiting for my carb kit to come in, I decided to 'start the project' and prep some stuff. One of the twitchy things I wanted to address is my crappy carbs...
DSCN1480 by Dr. Frankenstein1, on Flickr
Here's the set-up:
DSCN1499 by Dr. Frankenstein1, on Flickr
So after jotting out a course of action, I decided to soak them - well, that one at least - in that Gunk Carb Cleaner stuff. I figured it couldn't hurt. I put the bowl seen above in, and about 4 hours later I ended up with this:
DSCN1500 by Dr. Frankenstein1, on Flickr
That same carb set-up looked like this now:
DSCN1502 by Dr. Frankenstein1, on Flickr
Yup, same bowl, same carb! I was lovin' it. But the big problem was those shellacked-in float pins. The Gunk-soak got the float to move stiffly up and down, where previously it was frozen solid, so I decided to try to tap it out, and finally wound up using a small-diameter, orange-handled pick from Harbor Freight; maybe you know what I'm talking about...anyway, the shaft of that pick finally got too big for the hole of the float arm, and I was so afraid I was going to break the float-pin mount so I had to come up with another solution to find something that was Hard enough, yet skinny enough to get into that hole, and finally landed on this:
DSCN1501 by Dr. Frankenstein1, on Flickr
One of those tiny screwdrivers for watches and really small screws and such. You can get them at the dollar store, and they even come with a nice wide head to make for easy tapping! I used the tiny Philips-head one, and it made the tapping-out SO much easier! Anyway - thought I'd share that nifty tool tip.
While I was in there I decided to go ahead and see about the water pump; I got the hoses off, but was then confronted by this - the Honda shop manual I have says to just unbolt the cover and take it off, but some Hero before me had decided to paint the engine case (!), effectively sealing the cover to the case! In this pic the bolts are still on, obviously, but I did remove them before I tried to take off the cover:
DSCN1495 by Dr. Frankenstein1, on Flickr
I tapped it lightly at first, then more heavily with a rubber mallet; I tried heating it up and then tapping it, I tried gently hitting it with the shaft of a rubber-handled hammer, gently prying it with a screwdriver, and even tried to get into the gasket by tapping in a razor blade to try and loosen it but I didn't like that, I'm afraid I'll screw up the mating surfaces...any idea on how to pry that thing off of there?
'75 Progress
- Dr. Frankenstein
Re: '75 Progress
I'd try tapping a metal blade putty knife in between the housing and engine case. The blade won't be much thicker then the gasket so it shouldn't mare the mating surface and if it does some gentle sanding should fix it.
- Dr. Frankenstein
Re: '75 Progress
Yes, I tried that too - started with the razor blade, then moved on to a really thin paint scraper. I saw a really thin, bright shiny band of metal forming under the blade, in the notch between the housing and case after I got in there about a quarter of an inch, and stopped because of the whole screw-up-the surface thing. I might try it again, but I don't know...I'd hate to really screw up the surface.
Re: '75 Progress
Actually, that's as far as you need to go to check the condition of the water pump. You can check it for side to side (should be none) and rotational play (very little). Off you need to replace the pump, you'll have a better opportunity to remove the cover with the transmission cover off...
- Dr. Frankenstein
Re: '75 Progress
Yes, I believe you're right; I just finished reading the Engine Renewal Process in Shoptalk, and my water pump (according to the post) is tight/good. Which is fine by me! I'll probably replace the O-ring, though. Couldn't hurt.
The thermostat seems fine, too, but they're cheap so I'll pick up a new one.
But Man..! I can't believe the PO spray-painted the ENTIRE engine flat silver! It's not so much that he painted it - but the Overspray is ridiculous. I had to take some acetone to the oil level window just to see into it, plus he got it all over the frame, and the final drive, the carbs and the manifold covers...the RIMS too! And just One of the front brake calipers!
So of course after all the years it sat somewhere - the last time it was inspected was 1998 - it gets all flaky, and just looks like crap; except for the valve covers, where it looks like heat from the engine baked it on... There's not a lot I can do with the case itself, but I sense a lot of elbow-chrome in my future.
Re: '75 Progress
Honestly I'd pull the trans cover and change the water pump. I've had an original pump that had zero play. Once it was all put back together it leaked out of the weep hole. Had to drain new coolant and oil and change the pump. May as well just do it now.
Re: '75 Progress
I won't argue with this advice... every one of my bikes has either had the water pump replaced before I bought it, or has been replaced by me. While I understand the 'don't fix it if it ain't broke' philosophy, I also want my bikes to be as dependable as possible. I guess it's just one of those now or later things, in my humble opinion...robin1731 wrote:Honestly I'd pull the trans cover and change the water pump. I've had an original pump that had zero play. Once it was all put back together it leaked out of the weep hole. Had to drain new coolant and oil and change the pump. May as well just do it now.
I'll add that sitting for an extended period of time (years) is probably harder on the pump and seals than being ridden daily. Many have reported no problems with the pump for 100k miles or more. My '76 had around 12k miles (and had sat for at least 15 years) when the pump needed replacement...
Re: '75 Progress
Time is one enemy of water pumps, the other is silicate in the coolant. Best to use Japanese coolant that is low silicate or Dexcool without silicate to make to shaft seal last.
- 7 Replies
- 818 Views
Last post by rcmatt007
- 12 Replies
- 664 Views
Last post by 5speed
- 13 Replies
- 1234 Views
Last post by mjsinil
- 11 Replies
- 383 Views
Last post by Toehead
- 1014 Views
Last post by John Schmidt
