'78 - pinched another loaf - Johnny 5!
Picked up this smelly pile in a Kentucky fence row for a Winter project (appropriate that I should pick it up on the first day of winter). GL1000s I've had are a '77 back in '04, a '78 with '75 motor (the Hunley), a junker '79 that I salvaged a few parts from and still have a few, a '79 that is set up for being my DD next summer when it is too hot for the GL1800, and now..... Johnny 5! (my fifth GL1000).
It is a '78. Came with the usual Vetter fairing and trunk, rotted-out K&Q seat, ancient tires. Last ran 9 years ago when his dad parked it in a barn. It turns over (with a ratchet on the alternator bolt). Present plan is to get it half-way complete and running, then sell for what I have spent (hopefully). Will need carb and brake rebuild, tires and belts replaced, seat re-foamed and recovered, frame and tins repainted. Fenders look Ok after straightening the kink in the rear. Need to find someone to swap the rear tail light with me - it has a '79 light on it now.
1976 Yamaha RD400c - rolling basket case winter '20-'21 project
1978 GL1000 - winter project for 2020 challenge - SOLD!
2006 GL1800 - the Black Pearl
1979 GL1000 project - to be restored
Ex '79 CB750F rat bike - the Rocket - SOLD!
- Jonesz
Re: '78 - pinched another loaf - Johnny 5!
I will be watching with bated breath! I am thinking that with your ability she will be soon crowned "the queen of the silver dollar". At least you have the headlight ears and a bucket. The rest can all be bought with $
Jonesz
1983 GL1100 Aspencade named "Freki" currently undergoing change to a standard. 95% Done
1979 Suzuki GS850
1979 Suzuki GS850
Or, dug out of a bucket in the shed. Not sure, but I think all that is needed for the headlight is in my "stash". There are a couple turn signals and stems for the front too, I think.Jonesz wrote:I will be watching with bated breath! I am thinking that with your ability she will be soon crowned "the queen of the silver dollar". At least you have the headlight ears and a bucket. The rest can all be bought with $
All voting for Queen of the Silver Dollar.
Yep! Like it or not, she's been named!Fred Camper wrote:All voting for Queen of the Silver Dollar.
Just curious, is your trailer a harbor freight special? I really should pop for one at some point...
Yes, bought it at the perfect time - they had corrected the wheels, sent out coupons for free LED replacement lighting. Then, they stopped selling them for a couple years. When they did resume, the price had increased by ~ $100! It sat in a shed still in boxes for most of that time until completion of the Hunley drew near. I put it together with the axle on top of the springs to lower it a bit, and the tongue moved out just a bit to make it a bit easier to handle and back (still very hard to back being so short). I added HF steel loading ramps upside-down as carry rail and treated decking lumber for walk boards on either side as I had seen too many Youtube videos of folks dumping their bikes and themselves while loading with nothing to brace their feet. This one loads nice. I can ride the Hunley onto it, put the kickstand down, climb off and strap down all by my self. Unload unaided too. The trailer will get a new paint job this Spring.Track T 2411 wrote:Yep! Like it or not, she's been named!Fred Camper wrote:All voting for Queen of the Silver Dollar.![]()
Started stripping her down today. Looks like the center stand mount will need rewelded when I get it stripped down. It goes over so far that the foot lever part hits the floor and causes the bike to lean to the right. Discovered an electronic ignition module in it. Turns out it is a Prestolite module. Will probably be pulling this down to the frame and repainting that as there is surface rust where things like crash bars were added. Bottom of the frame looks good, though. Front brakes off. Controls stripped. Intake manifolds unbolted. Noticed a broken off water manifold bolt, but that's pretty common. Penetrant soaking the crash bar U bolts overnight. A quick look in the tank shows minimal rust on first glance. Removed the speedometer cluster and key switch as the guy had lost the key (along with the key to his CB900 Custom) and this one has obviously been operated on. Ordered a replacement switch already. I'll re-key the shelter lock to match. Electrical interface box disconnected, unmounted, and a couple nuts located to hold it together.
Tomorrow I'll take the title down to the courthouse and get it transferred. Then on to stripping more down. I'd like to keep it on wheels until I can get it outside and pump the remaining gas out of the tank, then roll a dolly under the engine, take both wheels and the front end off before pulling the tank out. After removing the rack, I'll leave the engine strapped to the dolly and unbolt the frame from it and pull it off of the engine - probably pulling the swing arm/rear drive off to make it easier.
Sounds like you're making good progress on the bike. Thanks for the info on the trailer, as well!
The rack is off - flipped it over and there are at least 5 different screws out of the 16 bowl screws. Shelter frame removed and most of the electrical system disconnected/unbolted. Very poor 3 yellow wire connector replacement. I just cut the mess out and will use my RC hobby power connectors. Measured continuity between all three and none to ground so, that's good. Besides the missing three-wire, the eight position connector to the rectifier is toast. One connector melted, and one end on both male and female disintegrated. I'm convinced the proximity to the battery fumes causes this. All of the other connectors look Ok, so I hope they clean up well. I'm stalled until after Christmas as I have to do an oil change tomorrow and a few pre-Christmas chores. Hopefully after the holidays I can move the '79 back to the other side of the basement along with the Hunley so I have more room to work. I'll need that room to pull the engine. Also ordered a new 10L US cleaner tonight. And ordered a new(used) petcock - the outlet barb came off with the rubber line.
The outlet barb can be put back in. Those are just pushed in. Nothing special holding them. If you pull one of the elbows off the carbs where the idle air jet is it is the same way. Don't need any sealer or anything else. Just push it back in all the way.
1975 GL1000 parts bike (parts for sale)
https://www.youtube.com/watch?v=TV5ztdWx56I
Vintage Dr. Hook, love it
Nice work so far, this will be fun.
82 GL1100 Interstate-Oldewing (under going work, fresh frame, NEW motor)
68 CB 350 Hiding in my shed, soon my darling soon........
06 GL1800 daily rider
83 QR 50 Wifeys bike
76 GL1000 Fur Sail............
And always remember: beer has food value--but food has NO beer value...
I wish, but it broke part of the body out with the barb.robin1731 wrote:The outlet barb can be put back in. Those are just pushed in. Nothing special holding them. If you pull one of the elbows off the carbs where the idle air jet is it is the same way. Don't need any sealer or anything else. Just push it back in all the way.
While waiting for it to warm up so I could change the oil in the Equinox, I pulled the exhaust, wiring harness, front brake lines (trash), crash bars (also trash) and inner rear fender.
78 constantly modified/customized since 1978, BOTM June 2015 de-evolving this very moment https://www.ngwclub.com/forum/viewtopic ... 30&t=65511
76 Ltd "cookies bike" not ready for prime time,
79 project, finished,
'86 1200 (Beth's) with motorvation sidecar, July 2017 BOTM
'17 HD Road king and 08 HD Heritage softail (Beth's). I guess you can say we have MBS
Not much to add until after the holidays and sweet talking the wife into letting me put the '79 in the other side of the basement (so I have room to work). I did go out to the shed this morning and rifled through the spares from the junker '79. Brought back in some useful items like right controls (kill switch broken on the '78) and all eight intake runner bolts (a PO had replaced them with SS Allen heads on the '78). Also noted that I have all four intake runners in good shape from the '79 junker - the ones on the '78 don't look very good. There are two more big plastic storage boxes out there that still need to be gone through, but it might be best to just swap some from the garage with them. Once I get some room to work around it, I'll change the belts and then do a quick compression check. Even barring over with the alternator bolt it seemed to be pretty good, but I'd like numbers.
