'78 - pinched another loaf - Johnny 5!
Re: '78 - pinched another loaf - Johnny 5!
After several days of cleaning her bottom, I horsed the engine up onto another dolly (a lower one) and painted all that I can see/reach like this. Will let it cure a couple weeks, then do the top. The POR15 didn't come out as nice in Aluminum color as it did in MG Maroon. The metallic streaked a bit, and it didn't level as well but it will do.
Not happy with the POR-15 engine enamel this time. The aluminum color doesn't level well like the MG Maroon did, and although I spent about a half-hour stirring it, came out very streaked looking. It will do as this is not a true restoration, just a rescue.
Thanks for that review, good to know. Can it be sprayed or brushed? I never seem to have much luck with brush-on metallic...
No one seems to have been able to get that info from POR-15. The can just says to brush. It worked great in solid-color MG Maroon. I've read good reviews of black, also. Next time I do aluminum, I may rattle-can some VHT or Duplicolor.
there is no way you can brush a metallic... I would just "top coat" it from a can
Not liking that...
Look better with the belt covers polished some? Valve covers tomorrow.
My OCD would still be driving me crazy
Is temperature a factor?
Toss the carbs on and you won’t hardly see it....
- Liam
I had the same issue, I bought some engine enamel and applied some with a brush on a test patch, it turned out streaky just like that.
I think if you can spray on a coat of the same paint over that you would be ok.
70F in the garage - right in the recommended range.ericheath wrote:Is temperature a factor?
This would be fine if the paint was formulated for spraying. This is not, very high solids content. They don't even list a thinner.Liam wrote:I think if you can spray on a coat of the same paint over that you would be ok.
I think he meant get a rattle can of duplocolor and lightly top coat it
from POR-15 product page: (https://www.por15.com/POR-15-High-Temp)
"Clean up: Do not put left-over paint back into can. Clean all equipment immediately after use. At the same time, flush out all fluid lines and carefully clean pressure pots. Use clean POR-15 Solvent only. It is also good practice to periodically clean the spray tip or the fluid tip/air cap combination during the course of the working day or shift."
Also sell a thinner/solvent. Sounds like spray-able to me.
also sell it in rattle cans...could you topcoat it with same product in a spray can?
EDIT: that is the hi-temp coating, not the engine coating...?
Project bike "Dixie" - 1986 GL1200 Aspencade being rebuilt from ground up to be a naked 'wing. Build progress thread here: viewtopic.php?f=30&t=71959
Build log video: View it here
BOTM November '22
BOTM November '22
I'm not going to attempt any repair on the paint. Need to move on to other tasks. If it were a true restoration, show bike, or such I'd take it back to bare metal and spray. I don't want to invest more into it than I can expect to sell it for.
Looks a bit better with all of the covers polished, I think. They really do clean up nice!
