Hi All,
I shared my recent additions - Two 1977 GL1000s, plus a bunch of extra parts - on the intro thread. Thought I'd come over here to share a bit of progress, as I work to get both bikes up and running.
I knew I'd need to properly address the carbs as a first step on both of these bikes, due to neglect and improper storage treatment. I was told that one of them had recently had the carbs rebuilt by a local "expert" using Randakk's kit components. Seller said the bike was running poorly so he thought he'd get the carbs fixed up and see if that solved the problem. So, I took these carbs off first to see what might have been done incorrectly. Oh Boy...
The carbs had been butchered. Three of the float bowls were attached with oversized SAE screws. all of the jets were damaged - if not broken outright, several looked like they'd been extracted with a set of 10" vice grips! Two of the float hinge pin posts were broken off - and the guy had attempted a repair by forming new towers out of black SILICONE! The carbs had been soaked wholesale in carb dip - and only partially disassembled. I found fresh carb dip solution trapped inside several places. The throttle barely moved - evidently due to the felts being soaked with chemicals. On the other hand, I was able to save four brand new Honda needle and seats, with filters. They have the Keihin logo stamped on them so I know they are authentic. Also, looks like I may be able to reuse some of the new o-rings that were not contaminated. (Oddly, the guy did not use all of the kit o-rings - they were in one of the parts boxes still inside their little ziplock bags.)
So, I salvaged what I could - then held a quick memorial ceremony for these poor carbs that the "expert" had ruined.
I quickly moved to the spare parts shelf and grabbed a complete spare set of carbs that was included with the deal. I confirmed they were the correct version for 1977 - 764A. Then I cleaned off all the dirt, grease and grime from the outside, in prep for disassembly. This is when I noticed the idle adjustment screws all still had black plastic caps on them - that limited the travel (an emissions thing back in the day to prevent shade tree mechanics from messing with the setting). The closer I looked, the more they appeared utterly unmolested. None of the screws had been even minimally rounded out by use of the wrong Phillips, the secondary air hoses appeared to be OEM with the little wire clamps that have a curly q on the ends to pinch and release. The screws that held the plenum halves were still tightly set with factory lock tight - and were quite a challenge to remove. Even the brass float bowl drains looked like they had never been touched by a blade screwdriver.
What a shear pleasure this was - for me to be the first guy since 1977 to work on this carb set! Once inside, there was an incredible amount of black varnish. It appears the carbs were shelved full of gasoline, long since evaporated, leaving a glue-like tar everywhere. Brake cleaner melted most of this stuff pretty quickly. The only really stubborn components were the secondary jet tubes and the float bowl pins. But I was able to slowly and completely disassemble all four carbs without incident - using brake cleaner and PB Blaster in alternate rounds. I plan to proceed with the cleaning effort tomorrow. Then, unfortunately, I have to wait for Randakk to get kits back in stock. Still, this was real fun! Felt almost like being a kid again! I bet many of you can relate.
I am sorry I didn't take a single photo of this, I think I was just too much in shock to register that I ought to be capturing this for posterity...
Anyways, Be Well,
Rocky
77 Carb Set - Opened for first time!
Re: 77 Carb Set - Opened for first time!
You are the fortunate one, Rocky!
Cliff (74yrs )
No, I wouldn't know that elation as every set I've worked so far have been butchered. Last set had all but one of the 16 float bowl screws replaced with sheet metal, self-tapping or wood screws. The one correct screw was stripped. Save those bad units! You never know when there might be just the right part left for a future build. Add a #4 washer (not 4mm) under each needle and blue Locktite the grub screw 1/8 turn from tight to help the '77 off-idle problem.
Definitely save them - no matter the condition. There aren't going to be any new ones made. Good for spares or even rebuild with a bit of work. I know the feeling of the "virgin" carb set. I pulled some off of a 18K mile engine - no stripped heads or threads, no squished jets, no numbers hand etched in exterior surfaces. Just had to clean, replace gaskets and seals, and set float height. Like it should be.
- Dr. Frankenstein
I'm a little late to the party here, but did they look like this...? These were on my red '75 when I first got it...
DSCN1482 by Dr. Frankenstein1, on Flickr
See all that black shiny stuff...? All of these carbs were sealed solid with old, dried gas - it looks wet, but it's actually hard; the carb floats etc. did not move At All!
DSCN1480 by Dr. Frankenstein1, on Flickr
DSCN1479 by Dr. Frankenstein1, on Flickr
DSCN1484 by Dr. Frankenstein1, on Flickr
Here's what I did - I propped up the carb body enough to get each side into a little plastic tub filled with carburetor parts cleaner right up to the brim - y'know, that big gallon can they sell in Advance Auto/Autozone...? I let 'em soak for a few days, they seemed to come out okay...you can see how dirty the fluid got as it dissolved/fell off...
DSCN1499 by Dr. Frankenstein1, on Flickr
DSCN1500 by Dr. Frankenstein1, on Flickr
I don't have any pics of the finished product, but just like the bowl here, they cleaned/loosened up enough for me to get everything apart and put in a new carb kit.
fortunately the ebay '77 carb set in in great shape, except one idle screw was missing (and an OEM bag was in the plenum with the screw set
Dr. Frankenstein wrote: ↑Wed Nov 30, 2022 9:53 am I'm a little late to the party here, but did they look like this...? These were on my red '75 when I first got it...
and I thought mine off my 76 were bad..
I lucked out. None of the float towers were broke, all the jets came out in one piece and they all had oem screws.
- 18671344_10154757836775817_3446899377643780930_o.jpg (130.78 KiB) Viewed 270 times
- 18768342_10154762800505817_6341233260440199004_o.jpg (186.02 KiB) Viewed 270 times
- 18766736_10154767234210817_8200295184062463511_o.jpg (113.74 KiB) Viewed 270 times
- 31 Replies
- 2149 Views
Last post by Dr. Frankenstein
- 9 Replies
- 496 Views
Last post by Koboldwrangler
- 13 Replies
- 1374 Views
Last post by rcmatt007
- 633 Views
Last post by mwb4god
- 10 Replies
- 647 Views
