A GL 1100 menage a trois...
Re: A GL 1100 menage a trois...
Dot3 or Dot4 will work. You can mix those without issue.
You can use ATF or fork oil either one. ATF is ~7w. So you can change to a different weight fork oil to change the ride a bit.
- Jonesz
As Robin says. In addition I think most old manuals state Dot 3 cause that was likely "state of the art" 40 years ago. Dot 4 boiling point is 45 degF higher than Dot 3 so in my opinion better. When I changed over my 78 and 83 I made sure to pump enough new fluid through to make sure to flush out all the old Dot 3. Wasn't hard to tell as the old stuff was discolored and grungy looking.
Jonesz
1979 Suzuki GS850. Sold
There should be pictures of them here somewhere. I just use my imagination, and keep in mind both form and functionTrophyvictor wrote:Ahh good to know... Any tips on making one? Is there a post for that?CYBORG wrote:I no longer make them.... well almost never. Moved on to other neat thingswingrider wrote:For the aftermarket dip stick, I know Cyborg used to make a kit...not sure if he still does, and JC Whitney used to have one as well....
Here Is the link to Cyborg’s dipstick that he made...
Thank you for the tips... Gonna look up to it...
Today tackled the carbs... What a beast!! Or should I say dirty beast!!
- IMG_20200526_184524.jpg (129.12 KiB) Viewed 319 times
So.. I tackled the belts, and as a good pupil, forgot to attach the spanner to prevent it to move... And as it moved... I now have two marks... And forgot which one was aligned... I think in the red dot... If I reassemble the thing and turn by hand I should not cause any damage, but will I feel if not ok?
- 15912490960263002399680489978470.jpg (118.27 KiB) Viewed 305 times
The red dot (upper mark in your pic) is the correct one. If you look closely, you'll see a small arrow just to the right of it cast into the pulley. Once you install the belts, it is good practice to turn the engine over by hand several revolutions and re- check your marks. I also readjust the tensioners
Things are going well... Waiting for belts to arrive and painting bit's and pieces...
Restom as a paint to retouche frames with a brush, guarantee no marks, anyone as already used it?
Painting the engine in the frame is never the best result but it actually got better than expected...
- IMG_20200606_135436.jpg (176.17 KiB) Viewed 286 times
- IMG_20200606_135515.jpg (128.47 KiB) Viewed 286 times
- IMG_20200606_135508.jpg (167.49 KiB) Viewed 286 times
It's what I thought... Always good to have confirmation from masters...Track T 2411 wrote:The red dot (upper mark in your pic) is the correct one. If you look closely, you'll see a small arrow just to the right of it cast into the pulley. Once you install the belts, it is good practice to turn the engine over by hand several revolutions and re- check your marks. I also readjust the tensioners
I'm hardly a 'master' lol. I just (sometimes) learn from experience!
Progress looks good!
Some progress.... Bits and pieces... The paint I used is a inox spray... Works very nice... Makes an excellent finish and no drips...
And some polishing... Shine!!!
- IMG_20200613_181959.jpg (105.84 KiB) Viewed 268 times
- IMG_20200613_181839.jpg (186.05 KiB) Viewed 268 times
Looks good...
GL1100 1981 (A bike that is determined not to be ridden...!)
Thing's going a bit faster than expected...
- IMG_20200615_183811.jpg (209.88 KiB) Viewed 238 times
- Better than 1 wing only two wings...
- IMG_20200620_141402.jpg (211.26 KiB) Viewed 238 times
- Still a bit and pieces to sort out, but she's up and running...
- IMG_20200620_141420.jpg (197.11 KiB) Viewed 238 times
I will take some better pictures, but thanks already for the help...
There's still one more to do, the 80, that one is gonna be more radical build... But we will wait for the winter...
- 14 Replies
- 314 Views
Last post by Sagebrush
